Old 02-14-2007, 11:51 PM   #1
shayrgob240
shayrgob240's Avatar
shayrgob240 is an unknown quantity at this point
Send a message via AIM to shayrgob240
Rebuild help
So I'm in the final stages of putting my motor back together. I do have some questions though that I would love to have answered.
1) I'm looking in the FSM and I'm seeing Valve spring seats. When I dissasembled the head, I didn't remove any. So I just put the springs in the head w/o the seats. I do have an s13 motor so maybe that design is slightly different (I'm looking at an s14 fsm).
2) One cam is painted orange and the other green. Which is intake and which is exhaust? I forgot to take note of that during dissasembly.
3) What do you guys do about cam to lifter clearance? Those shims are really damn expensive and I don't know if I have the $ to go through that. How bad is it if the clearance isn't up to spec?
4) There is a rather weird procedure for installing the timing chain in the FSM. Do i have to follow this procedure or can I install the head on the block first THEN worry about the lower chain? I really don't see why I can't do it my way.
Basically I just need this stuff cleared up real quick before I continue on w/ the rebuild. I should be finished shortly!!
thanks!
shayrgob240 is offline   Reply With Quote
Old 02-15-2007, 02:37 AM   #2
steve shadows
steve shadows's Avatar
I would have them installed by a machine shop...
Thats pretty gay man, there should be a designatiuon like r1 or r2 on the cam or someting else like I on one onad a box with dots on it in theother otherwise i do they still have the sprockets attatched
Its really bad, re-shimming should be required for any modification to the valve train especially any change in valve hieght as you may experience
What do you mean by do it your way? I always put the chain on the link matching the dot on the crank and then install the chain guides and then pull it taught and rop the head onto the block use a freind and then put the exaust cam in first wrap the chain around the sprocket then theintake...
thanks!
hope that helps get back at us or me etc.
Like Me on FaceBook !
Old 02-15-2007, 04:36 AM   #3
zugoi
zugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to beholdzugoi is a splendid one to behold
? How would that help he you just qouted what he asked.
Drunk posting FTW!
zugoi is offline   Reply With Quote
Old 02-15-2007, 08:47 AM   #4
shayrgob240
thanks!
1) Why have a machine shop install them? It looks EXTREMELY simple to put in. I just want to know if it's necessary on the s13 ka.
2) They are stock cams that I'm reusing from the engine. ONe has aa #1 on it and the other has a #5 on it. lol. For now I have the orange installed for intake and the green installed on exhaust.
I looked in Alldata and the cam lobe height is the same for exhaust and intake so I don't think it really makes a difference.
3)Yeah...I was just trying to get around it. I probably need new shims b/c I redid the valve seats and I cut the valves.
4) Check this out:
In that picture the head isn't on the block. Why not? Why can't I just put the head on first THEN put the chains on?
THanks
Old 02-15-2007, 08:48 AM   #5
shayrgob240
there are answers in there. I had the same question but then I looked at it closely
Old 02-15-2007, 09:16 AM   #6
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
4) Check this out:
THanks
You didn't really specify, is this a KA24DE?
Anyway you can the timing chain how you want. Thats how it's done if the motor is in the car and you wanna replace the chain/guides/tensioner without removing the head & replacing the head gasket. The head gasket has a loop on the front (to seal the timing covers) that the chain goes through.
GL
MELLO*SOS is offline   Reply With Quote
Old 02-15-2007, 09:26 AM   #7
shayrgob240
GL
Awesome!!! thanks for the quick reply.
PS- I have a DE
Old 02-21-2007, 10:45 AM   #8
steve shadows
haha, i replyed in the quote, and now im getting neg rep? lol
ill make sure its bold and underlined next time.
I hope it helps regardless.
Old 02-21-2007, 11:24 AM   #9
reaxion
reaxion's Avatar
reaxion is making a name for him/her selfreaxion is making a name for him/her self
Send a message via AIM to reaxion
for future reference, always keep track and label what you remove. and why are you using an s14 fsm for an s13.
reaxion is offline   Reply With Quote
Old 04-13-2007, 09:33 PM   #10
forgottenpromize
forgottenpromize is an unknown quantity at this point
S13 intake (240) - green stripe, first lobe is aligned with the pin
S13 exhaust (248) - orange stripe, first lobe is 4 teeth clockwise from the pin
forgottenpromize is offline   Reply With Quote
