Old 02-15-2007, 11:44 AM   #1
g6civcx
g6civcx's Avatar
Critique my parts list for doing timing
This is a redtop S13 SR. I'm redoing the timing. Let me know if I overlooked something, or if there are other things I should be doing at the same time since the front will be off the motor.
* FR Sport timing kit: http://www.frsport.com/OEM_Nissan_S1...it_p_1351.html
* S14 water pump: they say it has an extra bolt hole when installed on an S13 SR, but it doesn't leak and flows better. http://www.frsport.com/Nissan_OEM_S1...ly_p_2218.html
* Front cover and oil pump. http://www.frsport.com/Nissan_OEM_S1...ly_p_1099.html
* Oil pickup and gasket. http://www.courtesyparts.com/Merchan...de=15053-SR20T
* GReddy pulleys. I'm sick of wrestling with rusty ass pulleys. http://www.frsport.com/GReddy_135221...DET_p_821.html
* New belts. http://www.frsport.com/Bando_OEM_Rep...ts_p_1300.html
* Koyo copper radiator. I decided against aluminium because it's too fragile for my application. http://www.frsport.com/Koyo_S020252_...R__p_1767.html
* Koyo radiator cap. http://www.frsport.com/Koyo_SK_C13_1...ap_p_2219.html
* FAL electric fans. I'm ditching the stock fan and shroud. http://flex-a-lite.com/auto/html/345-nissan.html
* Billion thermostat from SPL, as per RN240's recommendation.
* GReddy oil pan. http://www.frsport.com/Greddy_135259...DET_p_822.html
I already have Samco radiator hoses.
Right now FR sport looks like the cheapest place to order from, and their service is excellent. If you have another good place to order from please feel free to share.
Old 02-15-2007, 11:55 AM   #2
McRussellPants
Greddy Pullies are weak, get something that underdrives the water pump.
How is aluminum too fragile, don't cheese into a curb at 40mph and it will be good.
McRussellPants is offline   Reply With Quote
Old 02-15-2007, 01:23 PM   #3
g6civcx
g6civcx's Avatar
Care to recommend another brand?
Aluminium has better cooling but is more succeptible to damage from debris, rocks, etc.
Old 02-15-2007, 02:33 PM   #4
HalveBlue
HalveBlue's Avatar
HalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond reputeHalveBlue has a reputation beyond repute
Only other things I can think of (you might have this covered already) is a timing light and new gaskets for all the stuff you might need to take off and put back on.
Perhaps think about saving your money on the pulley kit if you're looking to save a bit of money. Just take off all the pulleys, remove whatever rust you find, clean 'em up, and pain them. Good as new.
Up to you though.
Good Luck!
HalveBlue is offline   Reply With Quote
Old 02-15-2007, 02:37 PM   #5
g6civcx
g6civcx's Avatar
It has a new valve cover gasket so it should be good. I'll take another look and see what is needed.
I gave up on the water pump pulley. It's rusted on so bad I don't think I can get the fan off without cutting.
Thanks for the comments.
Old 02-23-2007, 05:39 PM   #6
kaotic
kaotic's Avatar
kaotic is a jewel in the roughkaotic is a jewel in the roughkaotic is a jewel in the roughkaotic is a jewel in the roughkaotic is a jewel in the roughkaotic is a jewel in the roughkaotic is a jewel in the roughkaotic is a jewel in the rough
Go with an aluminum radiator...
kaotic is offline   Reply With Quote
