Old 02-16-2007, 12:55 AM   #1
domo dorigato
domo dorigato is an unknown quantity at this point
Send a message via AIM to domo dorigato
SR circuit sports SS turbo lines
so i managed to install these turbo lines on my car but the only problem i have is the oil lines leaking from the block to the banjo fittings/bolt. i have tried the stock washers which leaked, then i put in the new washers and it still leaked.
it turns out the banjo fitting is a lot wider than stock and so i don't think it was threading all the way.so frsports sent me another fitting which was smaller and the same size as the stock banjo fitting.
i installed that with the new washers but it is still leaking. i have put thread sealant w/ teflon each time and still leaking from that part of the line.
what am i doing wrong here?
i was planning on buying a steel AN adapter but i don't know the size i need to the s13 SR block and fitting?
anyone have problem with the circuit sports lines?
domo dorigato is offline   Reply With Quote
Old 02-16-2007, 01:01 AM   #2
Dousan_PG
Dousan_PG's Avatar
probably doing it right
id ask them again because they are super cool maybe something isnt done right or jst problem w/ product?? not sure. they are usually pretty damn good!
ive always seen good stuff on takamotorsports.com too.
probably the only two premade companies id buy from, personally.
done and done.
Aaron
Pink GodziRa
Old 02-16-2007, 01:27 AM   #3
UNITEDMASTER
UNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to allUNITEDMASTER is a name known to all
Hello ,I have installed several of these kits from FRsport. With new crush washers look at them carfully some of them are flat on both sides. But some of them are flat on one side and the other side may apeer to have ring on it or part of it is raised.Butt the flat sides against the bajo fitting. Try that if it stilll leaks then I dont know. PEACE
MR JACKSON.
UNITEDMASTER is offline   Reply With Quote
Old 02-16-2007, 01:47 AM   #4
Ameer
Ameer is making a name for him/her selfAmeer is making a name for him/her self
I had the same crappy problem. But these did the job.
http://cgi.ebay.com/ebaymotors/12mm-...spagenameZWD1V
Ameer is offline   Reply With Quote
Old 02-16-2007, 01:51 AM   #5
domo dorigato
the washers i got were flat on both sides. hmm..
well i emailed them again. i'll just wait for a reply back tomorrow or something.
if all else fails couldn't i just bypass the banjo fittings and just go for an adapter?
I'm looking at the takamotorsports site right now and although the pictures are small..the black lines have no banjo fittings for the s13 oil lines.
anyone know off the top of their head what earls fitting they are using for the oil line to block?
Old 02-16-2007, 01:52 AM   #6
domo dorigato
i'll try those out.. thanks guys.
Old 02-16-2007, 01:55 AM   #7
Ameer
Trust me, the same shit happened to me. I couldnt sleep at night untill I did the research. Now I sleep at night knowing my turbo get fed its oil. Good luck with the project. P.S. If you are desperate and can't wait, you can locally pick them up in walnut,CA. Thats what I did.
Old 02-16-2007, 07:46 AM   #8
g6civcx
g6civcx's Avatar
For those still having problems and those who are looking, you need to get the standalone kit from Taka Motorsports. http://www.takamotorsports.com/
They also offer a banjo kit, but I prefer the standalone because of the problem mentioned above with the washers.
Plus Taka will give you tech support and customizations to your exact fitment.
