Old 02-25-2007, 01:17 AM   #1
grnappletree14
grnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfectiongrnappletree14 is close to perfection
SR help car wont start, have spark and fuel. wants to run but then dies right after.
i just got done with my sr swap.
i fix the power problem and spark and fuel now it doesnt want to start. the longest i had it runnting was for 20 sec, i sprayed carb cleeaner in the tb, and i want to start but then it dies. so i added some gas cuz my gas take was low, and that when i started it for a while the i died. everytime i try to start it, it sounds like it wants to run but then it dies. i have spark, and fuel. my dad said it might be a bad fuel pump. also everytime i turn the cas timing thing, i hear my fuel pump go on off is it so post to do that. any1 have any ideas, lmk thanks
grnappletree14 is offline   Reply With Quote
Old 02-25-2007, 01:22 AM   #2
drftwerks
check for powergoin to ecu, and grnd from the ecu
giantroboteyes.wordpress.com/
Old 02-25-2007, 12:06 PM   #3
grnappletree14
any1 else know of anything, i really need help
Old 02-25-2007, 01:07 PM   #4
g6civcx
g6civcx's Avatar
Originally Posted by grnappletree14
the power from the ecu doesnt turn on
What does it mean for the ECU to "turn on"?
Check ECU relay/fuse and ground, like what was said above. Then check the thick engine harness that goes to the ECU for broken or improperly connections.
Old 02-25-2007, 01:37 PM   #5
grnappletree14
my dad told me that there should be a light on the ecu when its on, there like a little holw where the light is and besides it there is a little knob thing that u can turn.
Old 02-25-2007, 07:17 PM   #6
drftwerks
ok here is what you do,
Step one get wiring diag
step two find out where the ecu get power from and find the pinout for the ecu
step three get dmm and test that pin to see if it has power
now follow the steps for the ground of the ecu.
Old 02-25-2007, 07:30 PM   #7
grnappletree14
thanks im going to go do that right now.
Old 02-26-2007, 01:44 PM   #8
drftwerks
let us know what happens
Old 02-27-2007, 12:06 AM   #9
grnappletree14
yea i figured it out,thanks drftwerks. now it doesnt want to start. the longest i had it runnting was for 20 sec, i sprayed carb cleeaner in the tb, and i want to start but then it dies. so i added some gas cuz my gas take was low, and that when i started it for a while the i died. everytime i try to start it, it sounds like it wants to run but then it dies. i have spark, and fuel. my dad said it might be a bad fuel pump. also everytime i turn the cas timing thing, i hear my fuel pump go on off is it so post to do that. any1 have any ideas, lmk thanks
Old 02-27-2007, 02:17 AM   #10
drftwerks
ok what was the fix??? and what exactly did it fix???
and for fuel pump, do you hear the pump relay go on then shut off?
buzz- click??
Old 02-27-2007, 05:10 AM   #11
cosil8e
cosil8e is an unknown quantity at this point
i had a similiar problem last summer. after i went through everything i could think of i basically did what drftwerks said and found that my ecu was blown. i replaced the ecu and it started right up.
joe
cosil8e is offline   Reply With Quote
