Can you Put ABS Rotors in a non ABS 240
Well like the title says can you put ABS rotors on an ABS 240sx this is a 89' 240sx will they fit and will they work the same way as the non ABS rotors............ HELP!!
![]() Join Date: Jan 2006
Let me help you please. I prefer english
"As the title states, I am trying to figure out if it is possible to put ABS brake rotors onto a non ABS 240sx. This is a 1989 240sx. Also, will the fitment and performance be equal to that of the non ABS rotors?"
ho ha ho chi chi |
#5 | |
But I'm just wondering cause I actually just called about getting new rotors (for an ABS 240)... and was quoted two different prices. One, higher price, for ABS, and another (lower) for non-ABS. Are you saying I could just buy the cheaper, non-ABS rotors, and they will still work?
![]() Join Date: Apr 2006
^now i know from all my days lurking around here that you know your shit, but from the days work back at the parts store I know they are not the same and autozone, advanced both show different part numbers for ABS and nonABS cars as well as brembo.
If I remember right the non ABS were like .8 inch larger in size. maybe it was just a half inch...either way the ABS model used the same stuff as the altima which had the slightly larger rotor to go along with the larger single piston caliper. i'm actually on my way out to the store now, i'll check the bremo catalog to see the actual difference is sizes. |
no, 89-94 ABS / non-ABS rotors are not the same. The parts store gave me the ABS rotors once and I had non-ABS, and the rotors rubbed the calipers like crazy. You have to cut away a bit of the clip in order for the rotor to fit, but its a pain. Get the right rotors and save yourself the hassle.
#10 | |
![]() Join Date: Jun 2003
s13 Chuki ABS rotors are 257x22
s13 chuki NON-ABS rotors are 252x20 the front pads and calipers are also different. rears are the same across the board. i don't know if this applies to the zenki s13 also but i would assume so. Quote:
#11 | |
Admin Asshole
![]() Join Date: Mar 2002
![]() Join Date: Dec 2002
I'll be damned. I knew the 97-98s were larger, figured it was just a changeover for the late S14s, so my deduction was the S13s should all be the same. I stand corrected.
mmmmmmmmmmmmmmmm I don't know I guess I'll get the right rotors the thing is that I can get some Drilled and slotted rotors for $20.00 brand new mmmmmmmm. I'll what happens
#15 | |
#16 |
yea sorry never got back home last night to post up specs from the brembo catalog but the difference is:
9.92 (252mm) without ABS 10.1 (257mm) with ABS the min thicknesses are also different at 18mm for non ABS 20 with ABS overall height which is bascially mesasuring the offset or full rotor and tophat hight is the same on both. non ABS rotors are only used on the 240sx while the ABS ones are used on G20s, ABS 240sx's, Sentra's, and Stanza's. |
#18 |
![]() Join Date: Dec 2005
no, they are not the same... idk bout those dudes up top giving you wrong info... probably cuase they havent tried puttin ABS rotors on a non ABS 240. i had extra ABS rotors layin around one time and thought the same thing... they sould fit... nope
#20 |
Well Im going to buy them it's only $20.00 it's a hell of a deal and I'll let you guys know what happens and if I can make them fit I also forgot I don't have stock 240 rotors I have the Infinity M30 front rotors wich are alittle bigger so I'll see what happens.........
