Old 03-08-2007, 02:20 AM   #1
s145tam
s145tam is an unknown quantity at this point
slotting struts for alignment
Im running kyb agx struts custom coil over w/ cusco camber plates. I have the plates set to maximum positive but when i took my car to an alignment shop and they said i have about -3 degrees camber all around. they want to charge me like 500 bucks to slot the struts.
I'd rather do it myself. Anybody know how to go about doing this? I suppose i would need a special drill bit... any suggestions would be apreciated
thanks!
s145tam is offline   Reply With Quote
Old 03-08-2007, 02:31 AM   #2
johngriff
johngriff's Avatar
Just measure a reasonable amount of space forward of the top hole, and match the measurement on all sides. Mark it with a sharpie. Use a dremel and a Carbide porting bit (about $25 for a good one from a tool shop, try mcmastercarr). Make sure you use cutting oil, and keep an eye on the temp of the strut body, that way it is not too hot, they are gas filled. BTW you only need to hit the top bolt.
[email protected]
Old 03-08-2007, 07:52 AM   #3
projectRDM
projectRDM's Avatar
^ What he said. Take your time, the strut body is thick as hell and doesn't cut easily.
Old 03-08-2007, 11:31 AM   #4
cdlong
cdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant futurecdlong has a brilliant future
Send a message via AIM to cdlong
is your car fucked up or something? that's crazy high even for stock parts, with camber plates you should be able to make it positive if you really wanted. there are usually several sets of holes in the top of the camber plates, are you using the right ones?
cdlong is offline   Reply With Quote
Old 03-08-2007, 11:36 AM   #5
!Zar!
!Zar!'s Avatar
Sounds like you installed them wrong.
Either that or your subframe is fubar.
Or you could buy eccentric bolts.
Old 03-08-2007, 02:19 PM   #6
drew935
drew935's Avatar
drew935 is making a name for him/her selfdrew935 is making a name for him/her selfdrew935 is making a name for him/her self
How low is your car? Wheel gap is how much?
I'm driving fast
-drew
drew935 is offline   Reply With Quote
Old 03-08-2007, 05:03 PM   #7
s145tam
Thanks for the suggestions!
yeah, i dunno, my car is pretty crazy...
i installed the camber plates and i think they only go on one way so i dunno how i could mess that up. My car is set low but its still pretty reasonable (2 finger gap btwn wheel/fender and about 2.75" ground clearance maybe?). I have 17s all around. I assume that if my frame was f'ed up that the guy at the frame/alignment shop would tell me...
do the make eccentric bolts for 240's that adjust 3 degrees? the highest ive seen was .75... where can i get those?
Old 03-08-2007, 05:55 PM   #8
drew935
drew935's Avatar
ok, I'm running s14se wheels, 2.25 finger gap at -1.3/-1.4 camber in the front
2.5 to 2.75 finger gap in the rear with -1.5 to -1.8 camber.
I have cusco zero2 coilovers and know that you should have enough camber adjustment in the front with even a one finger gap.
Oops, also I forgot to add that I have eccentric bolts in the front since they come with the coilovers. I think that they are set at the 3rd marking on it. So maybe that's what you might need on the fronts. My rucas are stock and maxed out on the setting.
I'm driving fast
-drew
Old 03-08-2007, 07:22 PM   #9
cdlong
Not 240sx parts, just an example.
see in the narrow slots (two on each plate) how there are several unused holes? depending on what holes the set screws are in determines the range of camber adjustment you have. you can change the range by changing the holes the set screws are in. check which holes you are using and get back to us.
Old 03-08-2007, 08:18 PM   #10
Nuisance Crew
Nuisance Crew is an unknown quantity at this point
If you use eccentric bolts in both the top and bottom hole you can double the degree of adjustability.
Nuisance Crew is offline   Reply With Quote
Old 03-09-2007, 02:28 AM   #11
s145tam
there are five holes arranged 0X0X0 where X are the bolts. It is adjusted to the max though because the center pilloball bearing is slid all the way positive and cant go any further. i guess it would be cheapest to just slot the strut and get it over with...
Old 03-09-2007, 05:25 AM   #12
jmauld
jmauld is making a name for him/her selfjmauld is making a name for him/her self
Send a message via AIM to jmauld
Can you get a picture of your camber plates installed?
Jason
'95 240sx SE
jmauld is offline   Reply With Quote
Old 03-09-2007, 10:19 AM   #13
drew935
drew935's Avatar
/\ ++ on the pictures. It'll help us help you out better
btw, those look like suby plates. hehe
I'm driving fast
-drew
Old 03-09-2007, 08:32 PM   #14
s145tam
sorry for the crappy photo skills...
i also just ordered some OBX eccentric bolts off of ebay for 20 bucks... i heard they kinda suck but i dont plan on racing them so i think it should be okay. right?
Old 03-09-2007, 08:41 PM   #15
jmauld
Well, you have a little bit more adjustment in the camber plates if you move the two small bolts in one space. However, with the placement of those plates, you really shouldn't have -3 degrees??? Are you running S14 control arms on a S13?
Another thing you can try to do is rotate the plate clockwise 120 degrees, and slide the adjuster to the other side. That will get you a buttload more caster and might allow you take out a little more camber.
Do your coilovers have camber built into them? Look at the hub mount and see if the holes are aligned parallel to the shock body or if they are at an angle.
I've never had much luck with the crash bolts. They always slip with me, and if try to tighten them tighter than spec, they break.
Jason
'95 240sx SE
Old 03-10-2007, 06:44 AM   #16
s145tam
i have an s14. im using kyb agx shocks and ground control coilovers w/ cusco plates. i think the plates only fit one way... Im gonna take off my wheels when i get back into town to check the if the hub.
Old 03-10-2007, 06:49 AM   #17
jmauld
Those three holes are equally space. You can spin that plate to fit in either of the three positions.
Jason
'95 240sx SE
Old 03-10-2007, 08:31 AM   #18
projectRDM
projectRDM's Avatar
I would seriously slot the strut before using eccentric bolts. The ones I've dealt with in the past can easily slip when tightened or when under load, and they're not the best grade steel. Three different times I tried removing one from a local's car and broke them in half, he finally sucked it up and let me slot them.
Old 03-10-2007, 05:14 PM   #19
johngriff
johngriff's Avatar
Do not use the eccentric bolts, they are more headache, and very UNSAFE. NOT RECOMMENDED!!!!!
[email protected]
