Old 03-15-2007, 05:01 PM   #1
xcusememisswyn
xcusememisswyn's Avatar
xcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfection
Help with a Q45 brake upgrade
I just installed Q45 front brakes on my ABS equipped S14, and took it for a short drive. When I press the pedal down the first time it gives very little response, but if i let off the pedal then apply the same force again, its brakes like a pro. I dont know why it would give me this problem, and i have bled the brakes a few times so theres no air in the system. I am just trying to figure out why I need to press the brake pedal twice before i get the stopping power i should expect from q45 brakes every time.
xcusememisswyn is offline   Reply With Quote
Old 03-15-2007, 05:07 PM   #2
articdragon192
articdragon192's Avatar
Were the bleeder screws on the brakes pointing up?
Need help?
Click here
Still stumped?
Try this
Here you go.
Old 03-15-2007, 05:17 PM   #3
markyboi
markyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to beholdmarkyboi is a splendid one to behold
air in the system
markyboi is offline   Reply With Quote
Old 03-15-2007, 05:28 PM   #4
xcusememisswyn
yes they are facing up, and i dont think theres air in the system, i put speed bleeders on and took my time to bleed the system clean, but i guess ill try again tommo
Old 03-15-2007, 05:46 PM   #5
projectRDM
projectRDM's Avatar
Did you unplug the ABS actuator before bleeding? If not, there's still air in the lines.
Old 03-15-2007, 05:55 PM   #6
95Kouki
95Kouki's Avatar
95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough95Kouki is a jewel in the rough
depending on the mileage you could've blown the O-Ring Seals of the master cylinder while bleeding your brakes...sediment collects on the unused part of the master cylinder bore and when you're bleed your brakes you use that unused portion that has a very small chance of damaging your seals...but it does happen...use a vacum bleeder...saves your leg...also get rid of the Air Bleeders...i had problems with mine....good luck man
People will always be haters...can't change that...just out drive them
95Kouki is offline   Reply With Quote
Old 03-15-2007, 07:00 PM   #7
xcusememisswyn
no, wheres that? sounds like an easy fix...
thanks
Old 03-15-2007, 07:29 PM   #8
GR8WHITE
GR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-knownGR8WHITE is making his/her stupidity well-known
Talking
hey man i had the same problem when stopping the pedal went down and was mushy but if i let off and hit them again they were firm at the top, i checked everything like you but i noticed that around the caliper boots the two big round ones around the pistons were moist with fluid and there was fluid on my rims, the calipers seals were leaking from sitting in a junk yard so everytime i hit the brakes a little fluid would come out but they would pump up and hold the second time i hit the brakes.
GR8WHITE is offline   Reply With Quote
Old 03-15-2007, 09:04 PM   #9
projectRDM
projectRDM's Avatar
thanks
Under the hood, the big shiny thing with brake lines going in/out of it. FSM clearly states to unplug the power to it before bleeding.
Please tell me you weren't serious.
Old 03-16-2007, 05:31 PM   #10
GR8WHITE
im not talking about the damn master cylinder i am talking about a similar problem that i had with my q45 brake swap that had nothing to do with the damn master cylinder.
Old 03-16-2007, 05:35 PM   #11
projectRDM
projectRDM's Avatar
Fuck are you yelling at? I quoted a completely different post that had nothing to do with yours. Period. Do you always attack people who discuss completely unrelated shit?
Old 03-24-2007, 01:20 PM   #12
altalti
altalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura about
after you pushed the brakes the very first time this problem went away right? if so this happens everytime you push the brake pedal the first time after doing brakes it takes an extra second for the piston to pop back out to its normal position after being compressed. thats why when you do your brakes you always press them once before yuou drive. if this is the case and it only happened once there is no problem.
altalti is offline   Reply With Quote
