Old 08-18-2002, 04:12 PM   #1
Itsuki
Itsuki's Avatar
Itsuki is an unknown quantity at this point
Ok my 96 is leaking something around the oil pan area, it seems to be dripping off of the side of the pan, when i touched it, it was a greenish color and the other night when i was driving my temp gauage was all the way on hot so i pulled over and turned the car off for 10 minutes then i started it back up and it was fine... anyone know if its coolant and if it is were it could be leaking from?
Itsuki is offline   Reply With Quote
Old 08-18-2002, 04:18 PM   #2
F3600
F3600's Avatar
F3600 is an unknown quantity at this point
Send a message via ICQ to F3600
looks Like your coolant .. but i dont know where it could be leaking look around all your coolant line
hope this help!
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
F3600 is offline   Reply With Quote
Old 08-18-2002, 04:41 PM   #3
BEISSEN
BEISSEN is a well-known jackass
Send a message via Yahoo to BEISSEN
yeah our coolant line or your lower radiator hose might have gone bad.
BEISSEN is offline   Reply With Quote
Old 08-18-2002, 06:29 PM   #4
Itsuki
Itsuki's Avatar
Hrm ok ill look, how can i check if my coolant is low? do i just look in the little resevoir tank?
Edit: spelling heh one day ill learn how <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
Old 08-18-2002, 06:30 PM   #5
Itsuki
Itsuki's Avatar
Ok, now my car overheats after 10 minutes of driving i guess im gonna replace all my hoses do a pressure test and flush the system, and replace the thermostat... hopefully this wil fix it
Old 08-19-2002, 03:43 AM   #6
kanekz
kanekz's Avatar
kanekz is an unknown quantity at this point
Try to get this fixed ASAP. &nbsp;Dont want to damage anything else like head gaskets and stuff to this nature. &nbsp;
One trick is to turn the heater up full blast while driving to lower your engine temp.
Blitz!!
kanekz is offline   Reply With Quote
Old 08-20-2002, 11:23 PM   #7
NutzDrifta
NutzDrifta is an unknown quantity at this point
I had the same problem your talking about. &nbsp;My coolant was dripping from the same place. &nbsp;It turned out to be my water pump. &nbsp;I think it's the same in your case, but be sure to check all the hoses first and what not before you buy any unneccesary parts.
NutzDrifta is offline   Reply With Quote
Old 08-21-2002, 12:21 AM   #8
Itsuki
Itsuki's Avatar
Thanks for the help i drained my system then i noticed that my lower hose was bad and my thermostat was also bad.. i check the water pump it was fine, but i think it was leaking around the seal so i put new silicone sealent around the thermostat housing and around the water pump area and then changed my hoses and thermostat and flushed and refilled the system and now it runs alot cooler than before and doesnt leak &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''> ..
