![]() Join Date: Mar 2003
S13 Manual Seatbelt Conversion - How-To
I have a thread on Zilvia somewhere about this, just thought I'd revise it better:
I just thought I'd do a quick write-up on how I did my s14 seatbelts to s13 conversion. I hated the automatic seatbelts, so I bought some s14 seatbelts from a fellow Zilvia. You can also use B12 Sentra seatbelts, the install is basically the same. Removing the stock seatbelts is pretty straightforward, so I'm not going to post it. I also forgot to take pics during it, that's why. ![]() Remove your seats and set them aside. Remove the black screws from the door sill. ![]() Take off the necessary panels. Most of my rear panels are already off, so it was easy for me. ![]() ![]() Now, take out the stock lapbelt and throw it away, no one wants them anyways. ![]() You can also remove the auto-seatbelt accessories as well. ![]() ![]() ![]() Now, make a small hole in the carpet where the seatbelt will bolt into. ![]() Here's the place where you screw the seatbelt into, thus making the small hole. It's the same place where you took off the stock lapbelt. ![]() Now, get the s14 seatbelt and screw it in. (Some s14 seatbelts I have seen are different than the ones I got, for some reason. I ran into others who had the same problem. As you can see the top hook is too short to hook into the hole, so I just used a ziptie for now. I'm going to weld a small piece of metal there later). From what I heard, the B12 Sentra belts fit perfectly, but don't quote me on that. ![]() ![]() After the bottom part, there's a hole right in the middle of this picture. ![]() Now, attach the next part of the seatbelt to the hole in the last pic. ![]() Now attach the end of the seatbelt into the bottom hole ![]() ![]() Now enjoy your manual seatbelts! ![]() ![]() ![]() |
