Old 03-28-2007, 08:56 AM   #1
9DSX_DRVR
9DSX_DRVR can only hope to improve
Max MPH
This post is not about TOP END MPH. I am interest in mph in each gear.
This is the info I found out
1st gear = 3.321
2nd gear = 1.902
3rd gear = 1.308
4th gear = 1.0
5th gear = .759
rear gear =4.083
Ok using the varios calculators, I came up with the following:
with stock wheels size 195R 15s = 24.2 in dia.
so with 6k RPM shift I would get max MPH for the following:
1st gear = 31mph
2nd gear = 56 mph
3rd gear = 81 mph
4th gear = 106mph
5th gear = 140mph
I don't have a working tach. So can anyone verify this info for me?
Thanks
9DSX_DRVR is offline   Reply With Quote
Old 03-28-2007, 09:09 AM   #2
DoriftoPnoy
DoriftoPnoy's Avatar
DoriftoPnoy is on a distinguished road
cool. wanna show your calculations? kinda curious as to how you figured this out on paper.
DoriftoPnoy is offline   Reply With Quote
Old 03-28-2007, 09:20 AM   #3
mrmephistopheles
mrmephistopheles's Avatar
There are online calculators for this sort of thing if you can use google.
Out of curiosity, why the need to know?
You shouldn't really be going over 75 or so on public roads. Def. not over 100, and especially not on stock tires.
Originally Posted by PHLIP
Old 03-28-2007, 09:35 AM   #4
irax
irax's Avatar
acording to the calculator i did 152 in my s13 automatic
this may or may not be correct accounting for windspead and resistance i was probably realisticly doing 145
irax is offline   Reply With Quote
Old 03-28-2007, 10:13 AM   #5
womenbeshoppin
womenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfectionwomenbeshoppin is close to perfection
Send a message via AIM to womenbeshoppin
realistically a stock 240 can only hit a lil above 120 i believe.
womenbeshoppin is offline   Reply With Quote
Old 03-28-2007, 10:22 AM   #6
s14dude
s14dude's Avatar
s14dude has a spectacular aura abouts14dude has a spectacular aura abouts14dude has a spectacular aura abouts14dude has a spectacular aura abouts14dude has a spectacular aura abouts14dude has a spectacular aura about
Send a message via AIM to s14dude
i dunno ive done 145.
s14dude is offline   Reply With Quote
Old 03-28-2007, 10:26 AM   #7
Wei240
Wei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really niceWei240 is just really nice
if it's downhill and you have aero, you can probably go for more,
change to a vlsd from j30 which i believe has a different gear ratio that'll net higher mph, forgot,
but in any case, we're not going to beat any land speed record... i can only picture the bolts on our car slowly unscrewing itself once it hits 90 mph, lol
Wei240 is offline   Reply With Quote
Old 03-28-2007, 10:48 AM   #8
s14dude
s14dude's Avatar
I have an R32 vlsd. Do you have any idea on specs of this? When i do a Wangan Run....my car tops out at 145......i feel like the engine has a little bit more power......but it seems im limited....maybe my diff? possibly wind resistance?
LOL at stuff unscrewing......i dont doubt it haha.
Old 03-28-2007, 10:51 AM   #9
!Zar!
!Zar!'s Avatar
s-chassis and wangan in the same sentence is lol.
Old 03-28-2007, 10:55 AM   #10
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
heybrandon its called a speedcut. i've done that a few times. Owned a turbo RX-8 untill i hit speed cut and it still took him a few seconds to catch me. and ure LSD has nothing to do with it.
Review Thread
bardabe is offline   Reply With Quote
Old 03-28-2007, 11:07 AM   #11
9DSX_DRVR
s13 Max MPH
I used a calculator online. But, I wanted to verify what the "numbers" say and what you get in reality. So here is the BIGGEST reason. I want to know the max MPH in each gear. ie what is the fastest I can be going in a gear and can down shift. So If I am in 5th gear I don't want to downshift if I am going over 106mph. So I am not really interested in the top end like everyone thinks this post is about.
Another reason is I don't have a working tach yet. Tachs in the SOHC cars won't work with the sr20 motor.
I am not sure if you mean anyone not going over 100mph or just the 240sx doing over a hundred. Because a recent car cruise I went on (not mentioning any names) consisted of about 28 cars and they were all doing over 100mph. I also meant stock size not stock tires.
Old 03-28-2007, 11:12 AM   #12
9DSX_DRVR
Stock ECU cuts you off at 115mph I believe. However, I have an RPS13 ECU which I can tell you for sure lets you go at least 125mph.
Old 03-28-2007, 11:19 AM   #13
s14dude
s14dude's Avatar
nah its not speed cut because the engine is still moving strong...just wont gain anymore speed.
and yes S-Chassis Wangan!
Old 03-28-2007, 11:27 AM   #14
irax
irax's Avatar
Automatic s13's dont have a speed cut
SOHC 5 speeds cut at 115
DOHC 5 speeds cut at 120
SR SHOULD be the same but I DON'T KNOW
And that is based off of stock speedo, different tires = different actual speed cut off
Old 03-28-2007, 11:50 AM   #15
jrmiller84
jrmiller84's Avatar
jrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond reputejrmiller84 has a reputation beyond repute
Send a message via AIM to jrmiller84
Exactly, you're passenger side floor panel will unscrew and fly out from underneath your car at those speeds
BitDestroyer.com
jrmiller84 is offline   Reply With Quote
Old 03-28-2007, 12:01 PM   #16
irax
irax's Avatar
Nah I had a 'danger to manifold pressure' warning light before hitting 90 I decided to back down then
Old 03-28-2007, 12:11 PM   #17
krazyfil
krazyfil's Avatar
krazyfil has made poor choiceskrazyfil has made poor choiceskrazyfil has made poor choiceskrazyfil has made poor choiceskrazyfil has made poor choiceskrazyfil has made poor choices
KA
haha... thats a joke... ive been clocked doing 147 before with a radar gun... and i was only at abour 6200 rpm.... so yea u can go faster... 120...lol.. your funny
krazyfil is offline   Reply With Quote
Old 03-28-2007, 12:24 PM   #18
s14dude
s14dude's Avatar
yeah no speed cut here......i think if i had a more straight and smooth road i might be able to do 147+
Old 03-28-2007, 12:32 PM   #19
projectRDM
projectRDM's Avatar
Scott Avoy ran his SR all the way out on a dyno, 5th gear redline was 172MPH. Realistically with drag and windspeed that's maybe 155-160. I've had my old car to 148MPH before, verified by the MDM-100, which receives signal directly from the VSS. Accounting for tire size that's about 145MPH.
The numbers above are good to use only if you're still running OE tire sizes, after that you can probably add another 5-10MPH on each one. I want to say my old car would do 35 in 1st, 65 in 2nd, 90 in 3rd, 115 in 4th, and 5th was whenever I let off.
Old 03-28-2007, 12:46 PM   #20
9DSX_DRVR
Thanks. Thats the answer I was looking for.
Its kinda hard to speed shift w/out a tach. But at least if I know the speed limit in each gear I can guess.
Damn, I need to get that tach soon!
Old 03-28-2007, 12:48 PM   #21
reflexdb
reflexdb's Avatar
reflexdb is making a name for him/her selfreflexdb is making a name for him/her selfreflexdb is making a name for him/her self
Send a message via AIM to reflexdb
So....here's the math:
Speed[mph] = (RPMengine)/(Gear ratio)/(Rear end ratio)*pi*(diameter of tire[in])*7.33
I don't know for sure if there is or isn't a primary reduction in the tranny or not. But if not, this will be your ground speed. Also, wind resistance is not going to change this number. The force from wind resistance will slow down your acceleration to this speed, and will limit top speed if your engine doesn't have enough power to overcome it. But if your going a set RPM in say 4th gear, do the math and that will be your vehicle speed.
reflexdb is offline   Reply With Quote
Old 03-28-2007, 02:16 PM   #22
s14dude
s14dude's Avatar
yeah im running the stock 15's. 148 sounds about right....i think ill top out around there if i get the change to drive on a longer straight.
Old 03-28-2007, 03:04 PM   #23
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
i've done 140 on mine
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-28-2007, 03:32 PM   #24
steve shadows
steve shadows's Avatar
Its all about wheel speed sensors and standalones.
Im planning on hooking one up. HWY runs are more dangerous to your bank account and driving record and your own personal life when its 330 AM then other people typically.
I have always had the personal policy of aiming for something hard and killing myself if I start to lose control than hitting some innocent person.
but yeah, depends. I’m running a 4.36 final with a sr 5 speed gear box.
Who knows how fast i'm going after _____ rpm in 4th gear for example.
Really really fast im sure.
I mean what does an E46 M3 top out at? I kind of pooped all over his investment.
When I get the wheel speed sensor iir to come back on here, ill let you know haha.
PS. the stock Nissan S13 SR Speed sensor is worthless after 128 mph or so as in drawing any sort of usable signal or speed reading.
Not sure if the s15 is better or s14 etc.
BTW I've done top speed pulls with the 3.90 LSD, the 4.10 and the 4.36.
The 3.9 was definitely longer however the 4.08/10 was better overall.
The 4.3 is nice and feels longer than I expected overall and is better for a car that sees lots of joshin-off and not just a specific straight line run.
It all depends on what your trying to do. I think the 3.5 is way too long unless you have a custom gear set and then it would be applicable for drag (using a nice gear with an auto tranny and good stall + 200 shot etc) for lots of traction etc.
Its all up to you folks im just rambling now.
Like Me on FaceBook !
Old 03-28-2007, 04:20 PM   #25
womenbeshoppin
srry, i didnt know stock 240s top out that high.
Old 03-28-2007, 04:23 PM   #26
mrmephistopheles
So get a DOHC tach. They're about $20 and take 15 minutes to install.
I meant anyone, not just 240sx. Essentially one of those 'just because you can doesn't mean you should' deals. I won't lie, I've taken my car to over 130mph, but it was a stupid immature thing to do. I put myself and others into a risky situation, and could've resulted in a grave outcome. Putting yourself in danger is one thing. I don't really care much about that - but when you jeopardize the well-being of others, you're in the wrong. That happens any time you drive recklessly on public roads. People frequently don't grasp the gravity of the responsibility of driving a car and how one error can lead to a lifetime of pain or death. So far, I've been lucky. I've been in one crash, and it's been on a closed circuit - completely my fault (overconfidence), and I never put anyone into danger that wasn't doing what I was doing.
I know 240s can go fast, but it's dangerous to others to do so, and not worth the brief thrill associated with it.
Old 03-28-2007, 04:28 PM   #27
DJ_Sunrise
DJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to allDJ_Sunrise is a name known to all
Send a message via AIM to DJ_Sunrise
154mph before cop clocked me.. and gave me a seatbelt ticket. somewhere around 5200ish rpm i want to say? J30 LSD. had plenty of room left to go faster. ran 130mph almost entire trip to penn state university from nj, normally 5 hr drive.. but popo caught me half way through. cock suckers, therese nobody on I80.
1st gear 35
2nd gear 67
after 2nd, i watch the road, not the gauges...
DJ_Sunrise is offline   Reply With Quote
Old 03-28-2007, 04:47 PM   #28
Motorhead
Motorhead is making a name for him/her selfMotorhead is making a name for him/her selfMotorhead is making a name for him/her self
Send a message via AIM to Motorhead Send a message via MSN to Motorhead Send a message via Yahoo to Motorhead
*happy dance*
Yeah baby. GT-R rear end, 3.63 ratio and a RB25 transmission.
Thank god for looooooooong legs.
Motorhead is offline   Reply With Quote
Old 03-28-2007, 05:40 PM   #29
s14dude
s14dude's Avatar
So is the R32 a 3.63? Anyone know what the ratio is for the R32 diff?
Im glad i have my GReddy TT, shows me digitally how fast im going. ^_^
Old 03-28-2007, 05:43 PM   #30
steve shadows
the digital signal fromt he two wire snesor - its useless over 130 mph as I stated.
