Old 04-04-2007, 09:05 PM   #1
onehundredoctane
onehundredoctane's Avatar
turn signals and hazards inop
first off I tried searching this topic before posting, but seems like the search function wasn't working either.
without going into detail I'm just trying to figure out whats wrong with my turn signals and hazard lights, when you turn on either turn signal the correct lights turn on, but DO NOT flash, they simply stay lit. Same is with the hazards, when the button is pressed all lights that should flash just come on and stay on.
I may be overlooking something simple, after wiring from the fuse box to the back of the car I have checked and double checked multiple times, this is merely a last resort to see if anyone has an idea.
I have replaced the relay for the signals, (located on the brake pedal mount) but that did not help.
thanks guys!
Old 04-05-2007, 06:46 AM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
try a known good flasher relay
Z U L8R is offline   Reply With Quote
Old 04-09-2007, 03:36 AM   #3
onehundredoctane
out of 3 I have here all of them shouldn't be bad, next thing to do is chase grounds and check all bulbs.
Old 04-09-2007, 03:43 AM   #4
C. Senor
C. Senor's Avatar
C. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfectionC. Senor is close to perfection
Send a message via AIM to C. Senor
check to make sure you have the proper bulbs...i got the wrong bulbs, ones with only one wire thing and the same thing happened, or your's could just be burnt out...cause the same problem (i think)
C. Senor is offline   Reply With Quote
Old 04-09-2007, 11:19 AM   #5
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
dual filament bulbs are your friend, please double check you got the right ones
pbcstylez is offline   Reply With Quote
Old 04-15-2007, 08:48 PM   #6
onehundredoctane
well I'm having a friend that is a wiring guru come over and look at it, with all the wiring I've done it's probbly a wiring issue, I guess I'll get him to wire up the 16 feature keyless entry also.
Old 04-16-2007, 12:30 PM   #7
pbcstylez
also most flashers have 3 wires, make sure you wired the 3rd one up correctly, most cases ppl ignore it and dont wire it up correctly thus the no blink effect.
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
