Old 08-26-2002, 08:53 PM   #1
240Dori
240Dori is an unknown quantity at this point
Send a message via AIM to 240Dori
and if it isnt are there ecu's that are made for running high octane amongst other improvements? i was thinking about getting an ecu....
240Dori is offline   Reply With Quote
Old 08-26-2002, 10:45 PM   #2
S14Drifter
S14Drifter is an unknown quantity at this point
i run my 240 on 94 octane! the highest street gas you can put, from sunoco. it says on the gas lid that 92,93 or higher is good if you want better performance. so you can run your car on high octane pump gas. it will not harm your car.
peter
S14Drifter is offline   Reply With Quote
Old 08-26-2002, 11:33 PM   #3
guidot
guidot is an unknown quantity at this point
Send a message via AIM to guidot
S14's are *required* to use 91 pump octane or higher, but the s13's could run on 87.
-Jeff T. 96 240SX
240SXONE
http://www.240sxone.com
guidot is offline   Reply With Quote
Old 08-26-2002, 11:43 PM   #4
tnord
tnord's Avatar
tnord is an unknown quantity at this point
i just run mid-grade for non-track driving. (90 octane around here)
tnord is offline   Reply With Quote
Old 08-27-2002, 12:45 PM   #5
Frappe
Frappe's Avatar
Frappe is an unknown quantity at this point
Send a message via AIM to Frappe Send a message via Yahoo to Frappe
I run mine 90 octane as well, except when I have to pass emmisions &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> &nbsp;or, rather, I suppose when I have to try and pass emmisions.
-Frappe
96' S14
(sold) '96 S14b
Zenki4ever
Frappe is offline   Reply With Quote
Old 08-27-2002, 03:49 PM   #6
the3SecondJerk
the3SecondJerk is an unknown quantity at this point
Just remember that higher octane doesn't mean faster....higher octane is harder to ignite. It is used in turbo vehicles because they run at higher temps and the lower octane will ignite prematurely under higher boost, this is called detonation. On a NA vehicle that isn't highly tuned it will provide little performace value.
Drive it like you stole it.
the3SecondJerk is offline   Reply With Quote
Old 08-28-2002, 09:06 AM   #7
Alias
Alias is an unknown quantity at this point
You guys should RTFM! &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> Mine for my S13 says to use 92octane. SO thats what I use.
Alias is offline   Reply With Quote
Old 08-28-2002, 11:16 AM   #8
the3SecondJerk
I was just saying any octane above what nissan recommends won't give any real performance gain. Sure it will run cleaner but it won't make your 1/4 mile drop by a half second. That's all.
Old 08-28-2002, 11:16 AM   #9
tnord
tnord's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sidewayzCA18 @ Aug. 27 2002,4:49)</td></tr><tr><td id="QUOTE">Just remember that higher octane doesn't mean faster....higher octane is harder to ignite. It is used in turbo vehicles because they run at higher temps and the lower octane will ignite prematurely under higher boost, this is called detonation. On a NA vehicle that isn't highly tuned it will provide little performace value.</td></tr></table><span id='postcolor'>
WRONG
if an engine was designed to run on high octane, running high octane in it will produce MORE POWER and will BE FASTER. if you don't believe me, read up on European Car's project M3, or C&D had an article not too long ago about it.
Old 08-28-2002, 09:46 PM   #10
sykikchimp
WOW addicted
sykikchimp's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (tnord @ Aug. 28 2002,1:16)</td></tr><tr><td id="QUOTE"></span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (sidewayzCA18 @ Aug. 27 2002,4:49)</td></tr><tr><td id="QUOTE">Just remember that higher octane doesn't mean faster....higher octane is harder to ignite. It is used in turbo vehicles because they run at higher temps and the lower octane will ignite prematurely under higher boost, this is called detonation. On a NA vehicle that isn't highly tuned it will provide little performace value.</td></tr></table><span id='postcolor'>
WRONG
if an engine was designed to run on high octane, running high octane in it will produce MORE POWER and will BE FASTER. if you don't believe me, read up on European Car's project M3, or C&D had an article not too long ago about it.</td></tr></table><span id='postcolor'>
even in our cars, The ECU is smart enough to detect when you have shitty gas in the car, and will retard timing to prevent detonation.. &nbsp;This WILL reduce you power. &nbsp;Run premium, and let the car do what it was designed to do. <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=''>
I think 89-90 S13's only req. 87 or 89 up.
Old 08-28-2002, 10:48 PM   #11
180wanab
180wanab is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Frappe @ Aug. 27 2002,1:45)</td></tr><tr><td id="QUOTE">I run mine 90 octane as well, except when I have to pass emmisions <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'> or, rather, I suppose when I have to try and pass emmisions.
-Frappe
96' S14</td></tr></table><span id='postcolor'>
just a note, the higher the octane is, the higher the emissions will be.
180wanab is offline   Reply With Quote
Old 08-29-2002, 07:54 AM   #12
Frappe
Frappe's Avatar
Wanab, that doesn't figure to me. Explain? I've mostly heard that higher octane burns cleaner.
(sold) '96 S14b
Zenki4ever
Old 08-29-2002, 01:08 PM   #13
MarketPlayer
MarketPlayer is an unknown quantity at this point
In my 90 fastback...if i run anything higher than 90 octane the engine will have really bad acceloration, and will blow out black smoke. &nbsp;I have done it three times and the exact same hing happened each time. &nbsp;I then ran it to emplty and filled up w/ 89 octane, and she purred like a kitten!
MarketPlayer is offline   Reply With Quote
