Old 08-28-2002, 02:20 PM   #1
tzonni
tzonni is an unknown quantity at this point
<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'> any suggestions?
tzonni is offline   Reply With Quote
Old 08-28-2002, 04:33 PM   #2
kanekz
kanekz's Avatar
kanekz is an unknown quantity at this point
Two words: Simple Green. I have used it on my engine bay before.
Go get a bottle of Simple Green All Purpise cleaner and spray it down on your engine bay. Make sure your engine is not hot. Let it cool off before doing this. After spraying down the dirty parts, let it set for a while. Brush the really dirty parts if needed with a toothbrush or something. After this, hose down the engine bat with a high pressure water hose (or you regular hose with ur thumb on the end). I HIGHLY RECOMMEND taking out the spark plugs and covering up the spark plug chamber so water does not get into them. ITs a PAIN if this happends. Trust me.
EDIT: AH yes, cover up the distributor cap as well, make sure it doesnt get wet.
Blitz!!
kanekz is offline   Reply With Quote
Old 08-28-2002, 04:39 PM   #3
negular
Dr. Neg
negular's Avatar
negular is an unknown quantity at this point
Send a message via AIM to negular Send a message via Yahoo to negular
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">After this, hose down the engine bat with a high pressure water hose (or you regular hose with ur thumb on the end).</td></tr></table><span id='postcolor'>
i've seen my friend spray his engine bay down at the pressure wash... he told me to do the same to my Z once, but i was to scared i'd fuck something up.
The louder the radio, the better I sing.
negular is offline   Reply With Quote
Old 08-28-2002, 06:04 PM   #4
hokiewalrus
hokiewalrus is an unknown quantity at this point
I've used Simple Green before with great results!
I'm a little too squeemish to take a hose to my engine, but I was able to clean it up with a clean sponge and a bucket of water...
hokiewalrus is offline   Reply With Quote
Old 08-28-2002, 07:11 PM   #5
S13Grl
Married to the Mob
S13Grl's Avatar
S13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to allS13Grl is a name known to all
You have to cover EVERYTHING electrical, not just the distributor and the spark plug wires. You have to make sure that your filter (if you have a cone) doesn't get wet. Make sure your MAF is covered, all your sensors are covered, make sure that your fuel rail is covered, make sure that your belts don't get too wet either b/c they'll start squealing and can possibly get out of adjustment, providing you get them wet enough.
S13Grl is offline   Reply With Quote
