Old 04-22-2007, 04:41 PM   #1
djtrickz
djtrickz is an unknown quantity at this point
Send a message via AIM to djtrickz
s14 Question about driveshaft center bearing cushion
its cracking all around but is still pretty intact. I'm just wondering if it will be ok for a while or does it need attention asap because i'm low on cash. thanks in advance for your opinion!
fixafixa
djtrickz is offline   Reply With Quote
Old 04-22-2007, 05:40 PM   #2
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
What year is your S14? How many miles on the driveline? Stock? KA Turbo? or SR powered?? Provided it's stock and you don't abuse the hell out of it, I don't think you have much to worry about. I've never heard of anyone having a driveline fail due to a center bearing cushion falling apart. The clutch / tranny are more proned to go out than that center bearing cushion.
Anyhow, hope this helps...
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 04-23-2007, 12:18 AM   #3
djtrickz
thanks yah i was thinking the same thing. i was just worried because i just put a j30 w/abs vlsd in and it pushed the shaft toward the front more and i caught that one forza show one time and this guy's driveshaft broke into the cockpit but anyways the car is 1995, almost 200k mi, no abs, stock ka with just pulleys.
fixafixa
Old 04-23-2007, 12:26 AM   #4
youngmanvr4
youngmanvr4 is making a name for him/her selfyoungmanvr4 is making a name for him/her self
I agree. I think your ok.
Current:
95 240SX SE - VLSD, S. Tech springs, S14 SR, Walbro pump, Nismo 3" catback, HDI FMIC, Koyo Rad.
95 3000GT base - Stock
94 3000GT VR4 - K&N Filter, Test pipe, Denso fuel pump, HKS EVC IV.
92 Ninja EX500 - Full Muzzy exhaust
82 Ford Courier Full Race Truck - 87 Ranger 2.0 engine with fully rebuilt bottom end, stage 2 post and polished head and race cam, Welded diff., K&N Huge Air Breather.
youngmanvr4 is offline   Reply With Quote
Old 04-23-2007, 12:47 AM   #5
reaxion
reaxion's Avatar
reaxion is making a name for him/her selfreaxion is making a name for him/her self
Send a message via AIM to reaxion
on my buddys 325i, that rubber wore out. one day he rolled into work and asked me to take his car for a test drive. I went to shift and BANG CLUNK BANG BANG BANG from underneath the car under the back seat. I was like "WTF...!?"
reaxion is offline   Reply With Quote
Old 04-23-2007, 04:56 AM   #6
g6civcx
g6civcx's Avatar
I would err on the side of caution and say you need to address it ASAP. If something goes wrong, you are the only one who has to deal with the consequences.
The center carrier bearing is very prone to failure on the stock 2-piece propeller shaft. Make a call to the Drive Shaft Shop and get yourself a nice 1-piece and eliminate that center carrier bearing.
Old 04-23-2007, 08:42 AM   #7
youngmanvr4
I bet if he wasn't low on cash he would.
Current:
Old 04-23-2007, 09:12 AM   #8
Spoolpigeon
Spoolpigeon's Avatar
Spoolpigeon is making a name for him/her selfSpoolpigeon is making a name for him/her self
i noticed that mine was the same way when i was under the car pulling the motor out. you could move the driveshaft around quite abit with just your hand. So i picked up some urethane and filled it up. It set up nicely and the squishey-ness is all gone. The car isn't together yet, but i'll let you know how it turned out.
P.S. the tube of urethane was $8, that's pretty low-buck
Steve-O
Spoolpigeon is offline   Reply With Quote
Old 04-23-2007, 03:39 PM   #9
djtrickz
you're right that was gonna be my next step, but the eurethane seems like a good idea too. let me know how it goes!
fixafixa
Old 04-23-2007, 03:47 PM   #10
MrMigs
MrMigs's Avatar
MrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond repute
Send a message via ICQ to MrMigs Send a message via AIM to MrMigs
Where did you buy that urethane from?
Drifting is just a compromise between you and your car.
MrMigs is offline   Reply With Quote
Old 04-23-2007, 05:05 PM   #11
Max_PSi
Max_PSi's Avatar
Max_PSi will become famous soon enoughMax_PSi will become famous soon enoughMax_PSi will become famous soon enough
I don't think your in trouble, yet. Do you have any clunking noises when you make turns, or does the DS resonate at certain RPM's? If it does then I would start saving, if not I'd say your ok, just make it your next mod.
My DS is shot, crazy resonating noises, and you can here the clunk from the DS flexing when I make right hand turns in particular. Just got my steel driveshaft from the Driveshaft shop today, will be installing very soon.
Max_PSi is offline   Reply With Quote
Old 04-23-2007, 06:48 PM   #12
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
mines like that youre still ok man its the the wear and tear over the years
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-24-2007, 09:22 PM   #13
Spoolpigeon
i got it from advance auto, but any car store should have this stuff. its called 'window weld' for installing windshieds and stuff. It hardens pretty good yet still slightly flexible. the only thing that sucks is that in only comes in a caulking tube, so you have to have a caulking gun to use it
Steve-O
