Old 04-20-2007, 05:40 PM   #1
93 240 s13
93 240 s13 is an unknown quantity at this point
tail lamp fuse keeps blowing
ok so my tail lamp fuse keeps blowing... and i cant figure out why...
i have the gauge cluster out and looking for a reason that it would be blowing..i dont see any loose wires or anything.. i have also followed the wiring harness from the tail lamps to the fuse panel and dont see any broken wires...
this only happens when i turn or hit a bump..
any advice someone can give me would be great
thank you
Brandon
93 240 s13 is offline   Reply With Quote
Old 04-20-2007, 05:54 PM   #2
SDS13COUPE
SDS13COUPE's Avatar
SDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant futureSDS13COUPE has a brilliant future
Does the fuse blow when you hit the brakes?
SDS13COUPE is offline   Reply With Quote
Old 04-20-2007, 06:03 PM   #3
93 240 s13
no its really random when it blows
i have drove 50 miles with out it blowing..
or i drive 10 miles and have it blow 4 times
i might have just found out why.. my driver side front marker light wire looks like it got ripped out... and it was touching my side mount.. does that sound like a reason why that fuse would be blowing...
im not sure if the side markers are on the same fuse though.
Old 04-20-2007, 06:14 PM   #4
SDS13COUPE
SDS13COUPE's Avatar
If it's grounding out it could be cause of that. Reattach those wires and see if it helps.
Old 04-20-2007, 06:20 PM   #5
nismo-joe
nismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud ofnismo-joe has much to be proud of
lol when people say its GROUNDING OUT makes me laugh.Its making a direct short against your chasis, and thats why its popping.
nismo-joe is offline   Reply With Quote
Old 04-20-2007, 07:12 PM   #6
93 240 s13
well im hoping that ould be the reason... i dot have any tools with me... im at work so i cant test it... but i guess ill find out on my way home in a few hours
again thank everyone for your help and ideas
if this did not fx it ill be back to ask more questions
Old 04-21-2007, 12:26 AM   #7
ixfxi
Guest
Posts: n/a
hahah YUP.. i was laughing as well. One time i had a tech at mitsubishi tell that to one of my customers. what a crock of shit.
its a dc circuit, it needs to have a ground or else it wont work (illuminate). in this case, the circuit itself has a short. you need to find that cut wire which most likely contacts your chassis and this happens over bumps.
peace
Old 04-21-2007, 12:28 AM   #8
aznpoopy
aznpoopy's Avatar
another common trouble spot is the orange wire behind the radio. check that if what you found isnt the problem.
Old 04-21-2007, 04:43 AM   #9
g6civcx
g6civcx's Avatar
A bad ground or short will increase the resistance in the circuit, which creates a current spike and blow the fuse.
Old 04-22-2007, 12:47 PM   #10
idlafie
idlafie's Avatar
idlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to beholdidlafie is a splendid one to behold
Side marker lights ARE on the same fuse. They are part of the ILLUMINATION circuit which consist of dashboard lights along with front & rear side markers. If the wire providing power to your front side marker light touches any grounding metal on your car, (such as the car body itself..in your case it was the side mount intercooler), then it would cause an "electrical short" causing your fuse to blow out.
Anyhow, glad to see you were able to figure out what your problem was. Were you able to fix it yourself? Hope you did.
ID
Weekend Mechanic for my Not-So-Mechanically-Inclined buddies....
idlafie is offline   Reply With Quote
Old 04-24-2007, 02:29 AM   #11
93 240 s13
yup that was the problem and im glad i figured it out, it was driving me crazy
i did figure it out my self
in december i had slid off the highway doing about 10 mph do to snow and bald tires and nailed a metal fence tearin the marker light out... never had a problemm untill couple weeks ago...
random
well thank you everyone for your help
much apperciated
Brandon
