Old 04-25-2007, 08:18 PM   #1
vbl
vbl can only hope to improve
Need HELP with RESISTOR
here is the part i bought from this website: http://www.jgstools.com/turbo/ka24et.html
i bought 4 resistors from that website and i try to install into my SR, but i dont know how. On the website said "install each resistor on POSITIVE SIDE". They mean install each resistor on RED wire of each injector on my Red Top SR. I heard same color wire of 4 injectors are ground wire, I'm so confuse now, PLEASE PLEASE Help Me, thanks.
vbl is offline   Reply With Quote
Old 04-25-2007, 08:21 PM   #2
statik
statik's Avatar
statik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond reputestatik has a reputation beyond repute
Send a message via AIM to statik Send a message via MSN to statik
common wire in the injector harness is 12v, red wire, you can also use a multimeter for things like this...
97 240sx esaarr | Current Status: SOLD
statik is offline   Reply With Quote
Old 04-25-2007, 11:00 PM   #3
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
you have to physically cut the wire and connect the resistors in between the two halves.
undesiredshoe is offline   Reply With Quote
Old 04-26-2007, 05:59 AM   #4
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
the 12volts are all red, the grounds at the ecu are all black, the grounds on the injector subharness are not all black. ^ cut the red wire on each injector plug and inbetween soldier your resistor, repeat for all 4 injector plugs. resistors are not like diodes, it doesn't matter if you have the gold or silver stripe facing any certain direction, just soldier that mofo in there AIIIGHT!@!!@ BUKAKE!!! @@
Z U L8R is offline   Reply With Quote
