Old 04-30-2007, 11:35 PM   #31
nosajton
nosajton is on a distinguished road
Originally Posted by street240 View Post
sleep look under a kick panel?????
most people i have tuned for 'want it to look stock' for some reason
nosajton is offline   Reply With Quote
Old 05-01-2007, 12:04 PM   #32
slideways2004
slideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enoughslideways2004 will become famous soon enough
Send a message via AIM to slideways2004
it looks like he doesn't have a q45 maf?
i have a few questions. if you have a tuned ecu like the one your selling, what would you set the safc to? like stock? also do you have rom tunes for s14 sr's with vtc. can you modify the vtc points? how much is one of your tunes?
slideways2004 is offline   Reply With Quote
Old 05-01-2007, 12:16 PM   #33
Josh K.
Josh K. is an unknown quantity at this point
I just ordered a tune from Jason (Emance), I'll let every one know my results.
Thanks Jason for looking at the bin on the ecu I bought. you saved my a#@!
Josh K. is offline   Reply With Quote
Old 05-01-2007, 08:44 PM   #34
Rockogtr
Rockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the roughRockogtr is a jewel in the rough
Send a message via AIM to Rockogtr
i also placed an order ...ill be posting some dyno sheets in a couple of weeks
Rockogtr is offline   Reply With Quote
Old 05-02-2007, 12:51 AM   #35
goj_cloud
goj_cloud is an unknown quantity at this point
hey jason i was wondering if you can tune my sr when i get my whole setup done and if u can tune for e85
goj_cloud is offline   Reply With Quote
Old 05-02-2007, 02:05 AM   #36
nosajton
sure can. are you local in san diego? you will absolutely love your car with e85.
you can expect about 20% more tq and hp over 91 octane at same boost level. e85 is much more tolerant to detonation.
what psi you plan on running? because you need to compensate for 30% more fuel. i am running 740's with fuel pressure bumped up to 70psi and i am at 85% IDC @ 22psi.
Old 05-02-2007, 09:58 AM   #37
Afliction523
Afliction523 is an unknown quantity at this point
I have only been on this forum a few times. This may actually be my first post. I usually am on NICO. Jason has done the tune for my ka-t. At first I thought I had a problem with my tune, but it turns out it was my setup. I had to move my mafs further away, and bam everything worked great. His customer service was quite well. I also looked inside my ecu to see his work. It looks clean, and better than I could myself. I just had to reseat the daughterboard like he mentioned prior to installing it in my s13. Mine works great, and I would back him up on it. I have been driving my car with no issues.
This is my setup
Top mont ssac
IHI RHC6 T3/T04e
Jecs 480cc injectors @ 80% Dynamic IDC
Walbro 225
z32mafs
hks ssqv (non recirculated) hot pipe
3in downpipe and exhaust
Auto to manual swap using the auto ecu
I also included a print out of my injectors to help with the tune.
Testing Information
Customer Name Steven Oliver Injector Type side feed high impedance
Application Nissan Testing Pressure 43.5
Manufacture JECS Set Qty 4
Flow Data
Static @100% IDC Dynamic @75% IDC
Injector # cc/min lbs/hr cc/min lbs/hr
1 540 51.4 432 41.1
2 540 51.4 431 41.0
3 539 51.3 434 41.3
4 531 50.6 429 40.9
Min Flow 531 50.57 429 40.86
Max Flow 540 51.43 434 41.33
Avg Flow 538 51.2 432 41.1
%Balanced 98.3% 98.8%
%Difference +/- 0.8% 0.6%
Latency
9v 7.66
12v 2.69
14v 1.37
16v 1.06
Afliction523 is offline   Reply With Quote
Old 05-02-2007, 10:46 AM   #38
goj_cloud
no im in norcal but once i finish my whole setup by the end of the summer they should have a couple of more e85 pumps in norcal
Old 05-02-2007, 01:07 PM   #39
nosajton
388whp / 436ft lbs KA-T on E85!!
i just got back from the dyno
check it out
that is t3/t4, z32, 740cc KA-T running on E85 @ 18psi
put down 388 whp at 5900 and 436 ft lbs at 3800
i think i would of hit 400whp if my stupid manual boost controller was working properly.
i will be back next week for another round. god i love e85
Old 05-02-2007, 01:24 PM   #40
S14DB
AFC #1
S14DB's Avatar
What fuel system changes are you making for the E85?
Old 05-02-2007, 01:31 PM   #41
nosajton
as hardware is concerned? nothing. tuning wise, you need about 30% more fuel
Old 05-02-2007, 02:28 PM   #42
goj_cloud
hey since e85 is a alternative fuled vehicle technically we should be smog exempt if we used it right?
Old 05-02-2007, 03:56 PM   #43
DP_Michelle G
DP_Michelle G's Avatar
DP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really niceDP_Michelle G is just really nice
^^ no i wish that could be
DP_Michelle G is offline   Reply With Quote
Old 05-02-2007, 06:14 PM   #44
S14DB
AFC #1
S14DB's Avatar
Originally Posted by Wikipedia
The primary differences from non-FFVs is the elimination of bare magnesium, aluminum, and rubber parts in the fuel system, the use of fuel pumps capable of operating with electrically conductive (ethanol) instead of non-conducting dielectric (gasoline) fuel, specially-coated wear-resistant engine parts, fuel injection control systems having a wider range of pulse widths (for injecting approximately 60% more fuel), the selection of stainless steel fuel lines (sometimes lined with plastic), the selection of stainless steel fuel tanks in place of terne fuel tanks, and, in some cases, the use of acid-neutralizing motor oil. For vehicles with fuel-tank mounted fuel pumps, additional differences to prevent arcing, as well as flame arrestors positioned in the tank's fill pipe, are also sometimes used.
http://en.wikipedia.org/wiki/E85
So the E85 won't eat my fuel tank, lines and hoses?
Old 05-02-2007, 09:13 PM   #45
timtiminy
timtiminy's Avatar
timtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the roughtimtiminy is a jewel in the rough
Send a message via AIM to timtiminy
Afliction523 vbmenu_register("postmenu_1358902", true); : who did the testing on your injectors? looking for a place to do the sti sidefeeds i just got.
timtiminy is offline   Reply With Quote
Old 05-02-2007, 09:33 PM   #46
Afliction523
I had mine done by Deatschwerks. I received the dynamic service for 16 bucks per injector. This was discounted from 24 bucks a injector since I was a member on NICO. I also received a free lag test(latency). They shiped them back via DHL, and is included in the $16 per injector pricetag. Im happy with the result.
Old 05-02-2007, 11:23 PM   #47
nosajton
no e85 wont eat your fuel tank lines and hoses. people mistake ethanol for methanol. methanol will eat through everything. ethanol is mildly corrosive. there have been tests done proving that ethanol wont hurt anything. as long as you change your oil every 3k or less, you wont have any problems running e85
Old 05-02-2007, 11:46 PM   #48
S14DB
AFC #1
S14DB's Avatar
Methanol oxides and eats aluminum like crazy. Ethanol is a solvent that will melt/dissolve rubber and plastics.
Old 05-02-2007, 11:59 PM   #49
nosajton
AMS on ka-t did a study on this, they have had rubber parts and aluminum parts submerged in e85 for over a year and they look just like they did on day 1
Old 05-03-2007, 12:49 AM   #50
Inland180
Inland180's Avatar
Inland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant futureInland180 has a brilliant future
Send a message via AIM to Inland180
Originally Posted by ?coupe240¿ View Post
ne one know ne thing about the digital speedos????
mine flickers on and off randomly..most of the time never on
why are you asking about this on this thread????
PTE6262 Full-Race Twin Scroll FTW!
Feedback LINK
Inland180 is offline   Reply With Quote
Old 05-03-2007, 01:43 AM   #51
street240
street240's Avatar
street240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nice
I was wondering the same thing.
The Gallo 24 would be a better motor for my skyline...But I am waiting on the swap dvd...
street240 is offline   Reply With Quote
Old 05-03-2007, 05:25 AM   #52
Inland180
Inland180's Avatar
just ordered a tune from jason... we"ll see how it goes. ill let you guys know.
Feedback LINK
Old 05-03-2007, 10:08 AM   #53
toledo240
toledo240's Avatar
toledo240 has a little shameless behavior in the past
the price you quote me is awesome :-) it seriously made my day much better knowing it is possible to spend hundreds of dallars especially when im doing a lighter tune for 300whp on a sr. Have you ever thought of doing the rechip thing, and giving you back the old one like enthalpy does???
also any warranties or money back guarentees???
toledo240 is offline   Reply With Quote
Old 05-03-2007, 11:00 AM   #54
street240
street240's Avatar
I was wondering also if you were going to start doing that. We would also like to see some Zilvia specials.
Old 05-03-2007, 12:17 PM   #55
toledo240
toledo240's Avatar
dewfintley group buy this.. and put me on
Old 05-03-2007, 01:05 PM   #56
nosajton
i do offer rechipping. current customers it is only $50 + shipping.
as with any high performance mod, there is no warranties. i am not responsible if you put the wrong gas in your car or if your mafs go's bad and leans out the motor, etc. but all of my tunes have been tested and work. if you have any problems, i will retune the car for free. this is why i recommend a knock lite and a wideband in every modified car.
Old 05-03-2007, 02:06 PM   #57
S14DB
AFC #1
S14DB's Avatar
Are you sure it wasn't Abel Racing in Oklahoma?
Old 05-03-2007, 04:06 PM   #58
Afliction523
I know I dont have much rep on this forum, but I can def. say Jason is a good guy to deal with. Many 240 owners in the chicago area know me, or know someone who does. His tune beats paying 500+ dollars hands down.
Old 05-03-2007, 08:46 PM   #59
Rockogtr
Did he do your tune ?? if so what's your set up and what are you making for power?? i have one on order and cant wait to see how my set up dose...
Old 05-03-2007, 09:44 PM   #60
Afliction523
My set up is posted a few posts up. He did my tune for me. I pull pretty good on my buddys STI. Its a 05 with a downpipe, and HKS exhaust. Im guessing 290-300whp on 9lbs. I had no problems with the tune. The ecu he sent me was a different code then my original, but functions properly. Just make sure you check that the daughter board is seated correctly. Shipping can jar it loose. From my experience he knows what he is talking about, and doing. I like my ecu, and there is no way I will ever pay 500 for another. The ecu looks clean inside. I suppose I can take it out of the car when I get over to the grage, maybe tomorrow. Ill shoot some pics if Jason approves.
