Old 05-09-2007, 02:20 PM   #1
TOMKAIRA93
TOMKAIRA93 is making a name for him/her selfTOMKAIRA93 is making a name for him/her self
SR SR20: block water inlet for turbo line "crosstreaded"
has anyo ne here faced this problem? If yes, what did you do to solve it?
I know you can do a variety of things, but I just want to have an idea of what most of you think is best to do.
TOMKAIRA93 is offline   Reply With Quote
Old 05-09-2007, 02:51 PM   #2
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
you can drill it out and helicoil it. You can use a keensert. You can weld it up and drill out a new fitting. You can drill it out, tap it larger and put an adaptor fitting inline.
Eye on the Prize
TheWolf is offline   Reply With Quote
Old 05-09-2007, 03:12 PM   #3
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
i had the same problem , look at my thread...i eventually used some threadlocker stuff but if i had to do it again probably would use RTV.
benefitx is offline   Reply With Quote
Old 05-09-2007, 03:48 PM   #4
cutter
cutter is on the path to ruincutter is on the path to ruin
Send a message via AIM to cutter
there is this stuff called super77 it is a blue rtv based high temperature thread locker. the stuff is amazing just goob it up with that, or red rtv.
i got a pin hole in my radiator and i drained it. cleaned it with brake cleaner and put some red rtv on the hole, and it held for 6 months till i got a new rad.. i would have never done that but i was in some financial trouble and didnt have a dime to my name.
cutter is offline   Reply With Quote
