Old 05-11-2007, 06:05 PM   #1
kendan
kendan is an unknown quantity at this point
Won't go into reverse
My brother has a stock 98 240sx se 5spd and I drove it fine for about 10 minutes I park it, come back out to drive it and it won't go into reverse. I have the clutch all the way to the floor and everything. All the other gears work perfectly. What could the problem possibly be?
kendan is offline   Reply With Quote
Old 05-11-2007, 06:12 PM   #2
eastcoastS14
eastcoastS14's Avatar
one of my old 240's used to do that....did you try forcing it all the way over and down, first time it did it I was like wtf... then i figured it would go into reverse if i put a little muscle into it
eastcoastS14 is offline   Reply With Quote
Old 05-11-2007, 06:13 PM   #3
kendan
yeah we've been trying to force it in. I'm kind of scared because it's not my car, and I was the last to drive it.
Old 05-11-2007, 07:03 PM   #4
kendan
The car has about 80k miles on it, do you think something needs to be replaced anyway?
Old 05-11-2007, 07:15 PM   #5
arkive43
arkive43's Avatar
arkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud ofarkive43 has much to be proud of
tranny syncros i think, keep playing with it dosent sound like u fuked it up...
arkive43 is offline   Reply With Quote
Old 05-11-2007, 07:18 PM   #6
kendan
fyi there are no grinds in any of the gears all of them shift perfectly it just will not go into reverse.
Old 05-11-2007, 07:28 PM   #7
vr4gasmtt
vr4gasmtt is an unknown quantity at this point
Try shifting into first and then try putting it into reverse. The reverse gear has no synchros, so putting it in first will let it glide into reverse easier. You couldn't have possibly done any damage by just driving it 10 minutes.
vr4gasmtt is offline   Reply With Quote
Old 05-11-2007, 08:21 PM   #8
spinitsidewayz
spinitsidewayz is making a name for him/her selfspinitsidewayz is making a name for him/her self
This works, or just let the car roll a little then stop and try again. My reverse is stubborn too.
spinitsidewayz is offline   Reply With Quote
Old 05-11-2007, 08:39 PM   #9
Ninjabread
Ninjabread's Avatar
I sometimes have to fiddle with mine to get it in, I just slide it in first and it goes right into reverse after.
Don't worry, you didn't fuck up anything.
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 05-11-2007, 09:19 PM   #10
Master240sx
Master240sx is an unknown quantity at this point
the way it sounds.. one of the spring broke out of the clutch..
Master240sx is offline   Reply With Quote
Old 05-11-2007, 09:30 PM   #11
eastcoastS14
stock 240 with 80k on it and driven for 10minutes....i doubt he wrecked the clutch
Old 05-11-2007, 09:31 PM   #12
Master240sx
you never know! its worth checking
Old 05-11-2007, 09:37 PM   #13
kendan
I tried to put it in first then reverse but it's still not going, so if I did break a spring in the clutch how much is it to fix?
Old 05-11-2007, 10:29 PM   #14
motonagam
motonagam's Avatar
motonagam is an unknown quantity at this point
When you shift a manual transmission into reverse, what you're doing is sliding an idler gear between two gears on the mainshaft and the countershaft in the gearbox. Sometimes the tooth on the idler gear will not line up with the tooth on the mainshaft and/or the countershaft gear, so that's what's happening. As previously mentioned, either putting the transmission into 1st or rolling the car a bit before putting it into reverse will help realign the tooth. I doubt you messed up the car.
motonagam is offline   Reply With Quote
Old 05-11-2007, 10:32 PM   #15
smurfgcr
smurfgcr is making a name for him/her selfsmurfgcr is making a name for him/her self
sometimes i have this problem too, i just pump my pedal and fiddle with the shifter. haha works every time.
smurfgcr is offline   Reply With Quote
Old 05-11-2007, 10:51 PM   #16
bo2o
bo2o's Avatar
bo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfectionbo2o is close to perfection
try shiftin to 4th then reverse
or turn off car and put it in reverse then start up
not so often does a 240sx tranny decide not to go into reverse.
if it were to be clutch clutch disc cost around 50 bucks
100 for a whole daikin exedy with throw out if you noe where to shop!
fS! vlsd ! slim fans ! hid kits ! lug nuts !
http://www.zilvia.net/f/search.php?d...earchuser=bo2o
^^^click^^^
bo2o is offline   Reply With Quote
Old 05-11-2007, 11:06 PM   #17
xblack240x
xblack240x's Avatar
xblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the roughxblack240x is a jewel in the rough
Send a message via AIM to xblack240x
Exactly as everyone said, mine does it too, just play with it, or put a little muscle into it, or put it in first then into reverse...
xblack240x is offline   Reply With Quote
Old 05-11-2007, 11:50 PM   #18
kendan
wow, thank you guys soooooo much I just went outside and put it in first and then reverse and it worked. Thank you guys so much I love this forum 10 times more now.
Old 05-11-2007, 11:54 PM   #19
Vision Garage
Vision Garage's Avatar
Vision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfectionVision Garage is close to perfection
Send a message via AIM to Vision Garage
You are welcome, search the forums and learn! Best 240 forum ever!
Vision Garage is offline   Reply With Quote
