#1 | |
Are ka24de coils the same as ka24e? *ANSWERED*
Hey i searched but are ka24de ignition coils the same as ka24e? I'm pretty sure that the ignitor chips (EDIT: should read power transistor) are the same, but i wanted to know if i can use a ka24e coil on my ka24de.
thanks EDIT here is the answer: Quote:
![]() Join Date: Nov 2006
might be wrong but ka's dont use coils do they? i think the sr only runs coils. but if your talking abou the spark plug wires then i would say no. i dont think the ka24e plugs go down in the head as much as the ka24de. the de goes in on top and the e goes in from the side. might be wrong but i think im right.
92 vert converted 5speed and other little things |
#4 | |
![]() Join Date: Sep 2004
Yes, all s13 coils are the same. The S14's run a completely different system.
------------------------- www.carolinanissans.com ------------------------- |
![]() Join Date: Dec 2002
1) Ignition coil
2) Coilpacks Two completely different things. BoostedCoupe- Don't post if you have no clue, you're only confusing others. allstock- There is no igniter on the KA, only a power transistor, which does not do the same thing. The KA uses a coil for all variations, however the S13 cars use an external coil while the S14 is internal within the distributor. The SOHC and DOHC coils are indeed different in design and mounting but do interchange. Hopefully future people will read the entire thread and get the right answer, not all the gibberish written above. |
#9 | |
Ok, so if S14 coils are internal, and S13 are external, why can't you rewire the S13 harness to use the S14 distributor and coil? (assuming you are putting a S14 dohc into a S13 dohc)
#13 | |
Yes, I look like that
![]() Join Date: Mar 2002
Why modify/fabricate some shit when you have a bolt-in alternative waiting to be used? |
