Old 09-07-2002, 08:08 PM   #1
orange-grey
orange-grey is an unknown quantity at this point
I read someone's post about removing the speed cut on an S14 a couple days ago and thought I would try it on my S13. It involved disconnecting the 5th gear sensor on the trans and cutting a yellow ECU wire with a green stripe and two silver dots every inch or so. On the S13 (at least mine) there is no such wire, but a yellow wire with a green stripe and a single silver band about every inch. There's actually two such wires, but only one goes into the ECU while the other bypasses it. I checked my Chilton's schematic and confirmed that this is still the speedo wire. I figured theres enough slack to splice it back together if it didn't work, so I went ahead and cut the one going into the ECU. Whoo-hoo, I took it out in the country and managed to wrap the speedo needle to the first odometer number! Although this proceedure is supposed to turn on the check engine light on the S14, mine has not come on. It flashes on startup, so I'm sure it works. I might put a switch in the kickpanel so I can turn it on or off if the light ever goes on. The 5th gear sensor is the same as the S14, its the rearmost one in the cluster of three small sensors on the right side of the tranny. Hope this helps somebody out there. BTW, my S13 is a '91 with the stock KA24DE and ECU. And of course, I'm not responsible if you screw up, get a ticket, blah blah blah, etc.
orange-grey is offline   Reply With Quote
Old 09-08-2002, 12:46 PM   #2
Natty
Natty is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (orange-grey @ Sep. 06 2002,10:08)</td></tr><tr><td id="QUOTE"> Whoo-hoo, I took it out in the country and managed to wrap the speedo needle to the first odometer number!</td></tr></table><span id='postcolor'>
Heh, you're my hero &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/thumbs-up.gif" border="0" valign="absmiddle" alt=':thumbsup:'>
I read that one post and allt he side effects scared me off, then at Radio Shack today, I saw some switches I could mount on the kick panel if I extended the wires. Just like you are thinking about doing.
hell, I may try that. I tried to whoop up on an automatic riced out Saturn SC2 on the interstate and I had it until I was coming up to my governor, so I backed off &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/cry.gif" border="0" valign="absmiddle" alt=''>
Thanks for being cool enough to be a guinea pig <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/sly.gif" border="0" valign="absmiddle" alt=':sly:'>
Jeff
1991 White 240sx Fastback LE, rusty spoiler, weak driveshaft, exhaust rattle....
Rattles are just your cars way of saying 'I love you.'
Natty is offline   Reply With Quote
Old 09-08-2002, 02:38 PM   #3
luke91
luke91 is an unknown quantity at this point
any way to do it to an s13 sr20det?
'91 fastback. &nbsp;'97 S13 blktop SR20DET. &nbsp;Cstm Frnt Mnt IC w/ cstm 2 1/2&quot; piping. &nbsp;stnls stl fltr. &nbsp;3&quot; cstm DP &amp; exhst w/N1 muff. &nbsp;Walbro FP. &nbsp;ACT 6 pck cltch. &nbsp;Go Fast Bits crnk plly. &nbsp;Ground Control coils. &nbsp;KYB AGX shks. &nbsp;12.98@106 w/g-tech pro. &nbsp;17psi. &nbsp;All work and fabrication done by ME
luke91 is offline   Reply With Quote
Old 09-09-2002, 09:26 PM   #4
91white240sx
91white240sx is an unknown quantity at this point
i took the speed limiter out of my SR20 by cutting that wire and i hooked it up to a switch and it works fine no problem yet. gonna try and to the 5th gear tranny thing this weekend.
91white240sx is offline   Reply With Quote
Old 09-09-2002, 09:35 PM   #5
Mtt22
Mtt22 is an unknown quantity at this point
i dont get why you would do both, would not one or the other work?
Matt
&quot;andy offers kevin pudding at 9, if andy is 7 years older then pudding than how many liters of andy does it take to get to detroit?&quot;
&quot;There are 3 types of people in this world. People who can count, and people who cant..&quot;
&quot;&quot;Save the Whales&quot; (Trade them for valuable prizes)&quot;
Mtt22 is offline   Reply With Quote
Old 09-09-2002, 09:41 PM   #6
LanceS13
AutoX Junkie
LanceS13 is making a name for him/her selfLanceS13 is making a name for him/her self
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (Mtt22 @ Sep. 09 2002,10:35)</td></tr><tr><td id="QUOTE">i dont get why you would do both, would not one or the other work?</td></tr></table><span id='postcolor'>
nope
LanceS13 is offline   Reply With Quote
Old 09-10-2002, 03:18 PM   #7
Mtt22
why not? if you cut the wire the computer will not be able to read yoru speed, and if you remove your 5th gear sensor.... fuck i dont get it
Matt
Old 09-10-2002, 04:41 PM   #8
DuffMan
DuffMan's Avatar
My understanding of it is the tranny has a sensor on the output shaft of the tranny to measure absolute speed. However there is also a sensor to tell what gear you are in. If you are in 5th it makes the rev limit lower.
For a demonstration of this, put it in 5th while stopped, and rev it up while hodling the clutch down. It will only let you rev to arround 5000something.
Old 09-10-2002, 05:16 PM   #9
Mtt22
oh, it all makes sence now, thanks
Matt
Old 09-10-2002, 05:43 PM   #10
Fresh 240SX
Fresh 240SX's Avatar
Fresh 240SX is an unknown quantity at this point
Send a message via ICQ to Fresh 240SX Send a message via Yahoo to Fresh 240SX
So there were no negative effects upon cutting this wire?
Fresh 240SX is offline   Reply With Quote
Old 09-10-2002, 05:53 PM   #11
Mtt22
there is one, apparently once you cut the wire the ecu goes into some kinda "warning mode" or something and no &nbsp;longer stores codes or something, i dunno, was in the last speed limiter removal post a few weeks back
Matt
Old 09-10-2002, 05:58 PM   #12
luke91
Wich two wires are we talking about here, exactly? &nbsp;Am I correct in assuming that if you disconnect the speed sensor, you render your speedometer useless, making this modification useful only for racing purposes, not for determining top speed? &nbsp;Anyway, where is the fifth gear sensor, and is the crucial wire on the SR20 still yellow w/green? &nbsp;All I remember hooking up when doing the swap was the reverse, and speed sensor. &nbsp;It's been a while, though...
We are still talking about SR20's here, right?
--luke
Old 09-11-2002, 12:34 AM   #13
mechaniac
mechaniac is an unknown quantity at this point
hey, I tried that and for some reason, my car wouldn't let me rev past 4500 in 4th gear, and 4000 in fifth, plus I couldn't go over 90! &nbsp;what gives? &nbsp;is this because I could have pulled off the wrong tranny sensor? &nbsp;which one am I supposed to pull off? <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/confused.gif" border="0" valign="absmiddle" alt='???'>
strive to be the fastest
mechaniac is offline   Reply With Quote
Old 09-20-2002, 10:47 AM   #14
i hate rice rockets
i hate rice rockets is an unknown quantity at this point
lolz mechanic...thats fucken funny..
95 240sx Se..
soon to have an SR
i hate rice rockets is offline   Reply With Quote
