Old 05-23-2007, 04:29 PM   #1
overb0ost
overb0ost's Avatar
overb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to behold
rear wheel hub warped?
ok this is the whole story.
i ran a semi warped rim that was balanced all winter and some of early spring.
i got slotted subframe bushings and coils recently installed and i started hearing a humming sound. i hear it more apparently when i accelerate at 60km/hr to 120km/hr and then fade away. i also don't notice much sound when i do turns or anything.
so i thought it was because of the new parts so i ignored it. just recently i put on my advan sa3s and found out the side that i ran the warped rim (rear right side), the advans wouldn't go on properly. the center bore would either be too tight on the left or right side, and only 1 side would go in all the way. the other side would go in 1/2 way. i then had to use my lug nuts to tighten it all the way to make them go on. so what is wrong here? my whole hub assembly or the studs?
i'm thinking if i should just change the rear hub assemblys with 5lug rear conversions like Ichiba.
could this warped rim really cause all this damage?
overb0ost is offline   Reply With Quote
Old 05-23-2007, 06:14 PM   #2
pr0ject TRUENO
pr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfectionpr0ject TRUENO is close to perfection
Send a message via AIM to pr0ject TRUENO
How are the bearings?
pr0ject TRUENO is offline   Reply With Quote
Old 05-23-2007, 06:29 PM   #3
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
easy way to check if its the studs or the hub, take a straight edge, and lay it across the hub and you will be able to see if there is any distortion there. also you could get a right angle and check the studs.
lazierhobo is offline   Reply With Quote
Old 05-23-2007, 09:53 PM   #4
overb0ost
overb0ost's Avatar
oh its that simple?
ok i'll do that and see how it goes.
lets say if both are pretty straight and theres its all contacting the straight edge at all points, what could it be then? the center bore got warped?
Old 05-23-2007, 10:36 PM   #5
projectRDM
projectRDM's Avatar
Sounds like someone at one time impacted a lug nut without centering the wheel, tweaking the hub's mounting flange a little. You should be fine with getting aggressive on it to fit, but definitely checking bearing play/noise first, it's possible the bearing is damaged anyway.
FORMERLY R240NA
Old 05-29-2007, 06:06 PM   #6
overb0ost
overb0ost's Avatar
ok heres the update
got a subframe and got the hubs from there but my mechanic said they weren't good since u could hear the metal touching each other when you spun it. it was smooth but made noise. bad thing i guess.
so we sanded down the hub on my car where the ring is and the rims fit good.
still makes the humming sound at 80-100km only on accerlation. not sure if its the bearing anymore, maybe something is resonating at those speeds.
i wonder if the subframe spacers could be the culprit of this humming sound i'm hearing
