Old 05-26-2007, 12:34 PM   #1
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
Write up to strip an engine
well i started my first engine build and so far im down to a bare block...im waiting on my bearings to get here so i wrote this little write up...
how to strip an engine down to a bare block in 30 steps
i wrote it in like 10 min so i maybe missing something
1) Remove entire engine
2) Remove turbo oil and coolant hardlines and return lines
3) Take off the exhaust manifold nuts and washers making sure you dont lose any
4) Remove entire turbo manifold along with the turbo
5) Take off the alternator along with all of its brackets
6) Take off the fuel rail and its bolts and washers
7) Start unplugging as many of the heater hoses from the intake manifold
8) Remove the upper intake manifold bolts and and 2 nuts on the side
9) Take off the intake manifold
10) Remove all the heater hoses
11) Remove water pump
12) Take off the motor mounts if you want
13) take off the valve cover
14) Remove timing chain tensioner
15) take off the cam sprocket bolts
16) take off the sprockets, let the chain hang or ziptie a wrench to it
17) remove the cam caps in order the FSM states
18) remove the cams
19) take off the rocker arms
20) remove the shims and rocker arm guides remembering the sides
21) remove head bolts how the FSM states
22) remove the 2 inner extra head bolts and 2 outer
23) remove the head
24) take off the crank pulley
25) Remove the upper and lower oil pans
25) remove the oil pump
26) take off the rear main seal
27) take off the crank girdle
28) remove the rod caps
29) wiggle the crank caps until they come off
30) take out the crank
benefitx is offline   Reply With Quote
Old 05-26-2007, 09:24 PM   #2
benefitx
i guess its not a good write up...cause it has no piccy's
Old 05-26-2007, 11:02 PM   #3
street240
street240's Avatar
street240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nicestreet240 is just really nice
Its not that...Its in the fsm.
The Gallo 24 would be a better motor for my skyline...But I am waiting on the swap dvd...
street240 is offline   Reply With Quote
Old 05-27-2007, 11:59 AM   #4
benefitx
but the fsm doesnt straight up tell you...oh well i fail again
Old 05-27-2007, 03:00 PM   #5
ecuastyle84
ecuastyle84's Avatar
ecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to allecuastyle84 is a name known to all
Send a message via AIM to ecuastyle84
pics of the process would of been nice
ecuastyle84 is offline   Reply With Quote
