Old 04-23-2007, 03:12 PM   #1
D1_King
D1_King is an unknown quantity at this point
KA KA24DE Hesitation
ya well when i start my car it starts up good, kinda idles up and down (100rpm or so). when i slowly step on the gas it starts to hesitate around 2000-2500rpm and its good after that. i thought it was bad gas so i ran the gas out and refueled it with new gas. could the fuel filter be clogged or the fuel pump, and also would the timing be off?
D1_King is offline   Reply With Quote
Old 04-23-2007, 03:15 PM   #2
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
mass air flow sensor @_@
Z U L8R is offline   Reply With Quote
Old 04-23-2007, 03:23 PM   #3
D1_King
ok ill check on that.
Old 04-24-2007, 01:34 AM   #4
BusBOy
BusBOy's Avatar
BusBOy is an unknown quantity at this point
Send a message via AIM to BusBOy
off the topic.. but i did had the same problem as u did...
but anyways, i now have a diffirent problem, my steering rack boot is rip and im planing on replacing it myself. i kno i can search and look for it but im too lazy, and top of that since i got the car my rpm doesnt work..
please help
BusBOy is offline   Reply With Quote
Old 04-24-2007, 01:40 AM   #5
kdashy
kdashy's Avatar
kdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfection
Send a message via AIM to kdashy
Maybe theres a leak in the intake or vacuum line on the intake past the MAF.
Unmetered air could cause problems like that until high rpms.
kdashy is offline   Reply With Quote
Old 04-24-2007, 02:27 AM   #6
SnakeKack
SnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of lightSnakeKack is a glorious beacon of light
Send a message via AIM to SnakeKack
I know it is not a 240 but my old 1990 300zx Z32 NA did that. it was the Knock Sensor. Couldn't hurt to pull ECU codes. 34 is knock sensor I believe.
SnakeKack is offline   Reply With Quote
Old 04-24-2007, 04:19 AM   #7
MrMigs
MrMigs's Avatar
MrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond reputeMrMigs has a reputation beyond repute
Send a message via ICQ to MrMigs Send a message via AIM to MrMigs
I say check the MAF, check the intake for leaks, and check exhaust for leaks.
Drifting is just a compromise between you and your car.
MrMigs is offline   Reply With Quote
Old 04-25-2007, 09:56 PM   #8
D1_King
word i get to that. but why would the knock sensor make the car hesitate?
Old 04-25-2007, 10:08 PM   #9
vincem
vincem is an unknown quantity at this point
i would like to know the answer also... why would the knock sensor do this?
vincem is offline   Reply With Quote
Old 05-13-2007, 01:30 PM   #10
wannabe_drifter
wannabe_drifter's Avatar
wannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to beholdwannabe_drifter is a splendid one to behold
I got a similar problem
Lets us know when you get it alright
wannabe_drifter is offline   Reply With Quote
Old 05-26-2007, 01:58 PM   #11
D1_King
yep well it still is messing up so. it have gotten better know that i reconnected my PCV system. i was stupid and took it off when i was taking all the emissions off.
Old 05-26-2007, 02:16 PM   #12
the terrible one
the terrible one's Avatar
the terrible one is on a distinguished road
check your maf and vacuum lines. check your intake for any signs of cracking in the tube or holes even. cracks before the maf sensor is nothing. after the maf sensor could cause some problems.
why would it be a knock sensor??? knock sensors detect pinging or knocking.
d1 king- are you experiencing any of that and you forgot to state that?
only thing knock sensors do is retard the timing when the engine detects pinging or a knocking.
the terrible one is offline   Reply With Quote
Old 05-26-2007, 05:39 PM   #13
junkey311
junkey311's Avatar
junkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymorejunkey311 is not welcome here anymore
check vacuum lines between the engine and firewall, and the EGR vacuum lines. better yet, you might as well replace them, because they are old and hard. and will leak eventually if they arent already. most common place for a vacuum leak
junkey311 is offline   Reply With Quote
Old 05-26-2007, 09:44 PM   #14
ka24kingmannyd
ka24kingmannyd's Avatar
ka24kingmannyd is a well-known jackass
Send a message via AIM to ka24kingmannyd
samething with me i swaped a sohc to a dohc and everything is good but i try to rev. it but its bogs out or something i dont know if its the ecu cause i have a bunch of ecu's but i dont know if their for the dual cam? help anyone....
ka24kingmannyd is offline   Reply With Quote
Old 05-27-2007, 01:09 AM   #15
jskateborders
jskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond reputejskateborders has a reputation beyond repute
Send a message via AIM to jskateborders
check the spark plugs.
jskateborders is offline   Reply With Quote
Old 05-27-2007, 01:24 AM   #16
airhead
airhead's Avatar
Trader Rating: (32)
airhead is making a name for him/her selfairhead is making a name for him/her selfairhead is making a name for him/her self
Feedback Score: 32 reviews
im having the same problem but how can i check for the vacum leak ?
airhead is offline   Reply With Quote
Old 10-30-2007, 04:16 PM   #17
BusBOy
BusBOy's Avatar
my car was heisitating too when my speedamotor wasnt working.. ever since i replace it, it ran like a stallion..
Old 11-04-2007, 09:09 PM   #18
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
so were you able to find out what the problem was? my car just started doing this.
i have all those signs except my car has a slight knock, and the exhaust smells like rotten eggs.
supreme_1 is offline   Reply With Quote
