![]() Join Date: Oct 2006
dropping the subframe to remove engine & tranny
ok so I totalled my 240 a while ago, im trying to pull everything i can from it and then scrap the shell....I was told that if you unbolt the subframe and remove it, you can pull the motor tranny and everything else all at once...anyone have any experience doing this, any tips would be helpful before i start
![]() Join Date: Apr 2006
disconnect everything, drop the front subframe, and it will all come out
2015 Subaru Outback Overlander - Wagonofdoom |
![]() Join Date: Apr 2005
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
I think it might be motre work than just removing the engine the traditional way. But yeah I guess undo engine/tranny X members. Pull out the driveshaft.
yeah it sucks because i dont own an engine hoist....and i really just need this thing out of my driveway so i can star work on my other one.....
![]() Join Date: May 2003
i'd disconnect everything unbolt the subframe/trannymount..etc and just lift the car from around the motor/subframe.
If its totalled.. just cut the radiator support out of the way put it on car dollies and roll it away from the motor. Other wise your going to need a lift or something to lift the car over the motor after u drop the subframe. |
![]() Join Date: Dec 2002
Crossmember, not subframe. Two entirely different things.
On the cars I buy, usually hit in the front, I wheel a cart underneath, cut the core support off, and drop the entire assembly on to the cart, then roll it out from the front. You can then pick parts of as needed and remove the transmission easily as well. Just remember to unbolt the column turnbuckle before you let it drop.
ha yeah sorry pulling everything out....I just need the body itself out of my driveway since its taking up so much space...figured i could unbolt my subframe drop everything a pull my VLSD 5lugs and all that a later point....also how do you guys usually unbolt the driveshaft...I cant really fit a ratchet onto the nuts
carrier bearing.. 17mm socket.
Rear diff to the driveshaft? use a wrench, pull up the ebrake to keep it from spinning on you.. then let the ebrake down.. spin the driveshaft to readjust, set the brake again.. until u get the them all off. Drift shaft just slips out of the tranny. |
