Old 06-04-2007, 11:39 AM   #1
PBucch
PBucch's Avatar
PBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfectionPBucch is close to perfection
MSD ignition tach output question
Hey guys, I searched and checked out the JWT page, but am still a little confused I am almost ready to start my car, got a few things left. Im putting a KADE into an 89 chassis, previous owner had an MSD booster and coil installed and the stock p00p was nowhere to be found. I know the OE stuff is great, but I dont have it.
Going by what he had hooked up I can tell what powers the coil, I dont have it in front of me sorry, but which wire of the three that goes to the coil is the tach signal?
THe booster puts out a tach signal at "12v square wave signal, 20% duty cycle"
Will this be fine for my DOHC tach to read? When the single cam was in hte car it had no tach reading at all, i assume it just wasnt hooked up....
Im thinking if it reads fine I can just put a plug on the wire and plug it into the boosters tach signal output right?
Thanks for any help,
Paul
section ef&ec changed my life
PBucch is offline   Reply With Quote
Old 06-04-2007, 09:19 PM   #2
PBucch
PBucch's Avatar
bump, anyone?
Old 06-04-2007, 11:59 PM   #3
G-spec
G-spec's Avatar
G-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of lightG-spec is a glorious beacon of light
I have a MSD DIS-4 box running my SR and didnt need a tach adapter to run my dohc tach. Works just fine.
GT3076r-boosted blacktop sr20det, s13 coupe
Function over Form...
G-spec is offline   Reply With Quote
Old 06-05-2007, 08:26 AM   #4
PBucch
PBucch's Avatar
I see, I am running a DOHC KA though, and using hte MSD coil, so I have no tach signal. anyone know which wire it is?
