Old 06-10-2007, 07:44 PM   #1
nismosil40zx
nismosil40zx is a well-known jackass
Send a message via AIM to nismosil40zx
SR S13 SAFC II Setup
I search SAFC w/ Z32 and found what I needed just really wasn't all to clear. I have a s13 redtop w/ a Z32 MAF what does the in and out need to be. I read 2 and 6 or 2 and 5. also heard2 and 2 from ethaphy. Also after you put that in it goes to a calc screen in 2 and then Add. whats that mean. And are the settings the same for a Q45 MAF if the z32 one doesn't work I m going to install that. If you guys can help me w/ the right adjustment that would be great. Thanks
nismosil40zx is offline   Reply With Quote
Old 06-11-2007, 01:33 PM   #2
slider2828
slider2828's Avatar
I think there is a operations manual you can read for the SAFC. Do a search on the web, not just here.
Old 06-11-2007, 02:10 PM   #3
nismosil40zx
apex gave me a install guide thats it
Old 06-11-2007, 02:12 PM   #4
sblack13
sblack13's Avatar
sblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud ofsblack13 has much to be proud of
it's 2in 6out for s13. and for s14 sr its 2in 5out with z32.
sblack13 is offline   Reply With Quote
Old 06-11-2007, 02:27 PM   #5
johngriff
johngriff's Avatar
2 in 6 out.
In represents the AFM you have chosen, Z32 which is represented as 2
Out represents the AFM the Ecu is anticipating, which if it is a stock ecu for an s13 redtop would be 6.
You probably read enthalpy telling someone to use 2 in, 2 out for one of his tuned ecu's anticipating a Z32 AFM.
2 in 6 out is what you need, if it does not, something is wrong with your setup.
[email protected]
Old 06-11-2007, 03:02 PM   #6
nismosil40zx
thanks for the help
Old 06-12-2007, 12:24 PM   #7
nismosil40zx
SR
So dou you guys no what the Q45 would be or would it stay that same as the stock maf?
Old 06-12-2007, 12:29 PM   #8
johngriff
johngriff's Avatar
Q45 is different, DL the pdf for the SafcII and look at the hotwire number next to the corresponding model year of q45 maf you have, that will tell you what value to enter for said AFM.
[email protected]
