Old 10-03-2002, 01:30 PM   #1
Pancor
Pancor is an unknown quantity at this point
I just bought a '93 Polaris Blue Fastback from the original owner, and I am LOVING it.  The car came with a JWT pop charger and ECU, and it actually rips quite nicely.
However, I've noticed that the clutch slips once in a while.  Usually jsut out of the blue, too.  even in 5th gear, I can pin it at about 3K RPM, and it'll slip like mad.  Are there any adjustments I can make to the clutch that might cure the problem, or is it worn out?   I'd really like to put a slightly more grabby than stock clutch in, so if its worn out, thats what i'll do.
Can you guys recommend any good aftermarket clutches, (not too grabby, but more than stock)?   I'd like it to last a decent amount of time as well.  Thanks
Pancor is offline   Reply With Quote
Old 10-03-2002, 02:13 PM   #2
Steeles
Steeles's Avatar
Steeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura aboutSteeles has a spectacular aura about
Send a message via AIM to Steeles Send a message via Yahoo to Steeles
yup its starting to go time to upgrade! <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''> &nbsp;as for recomendations. &nbsp;I like my SPEC stage 2 very light pedal feel grabs very well at the same time. &nbsp;some people have had problems saying they slip I have had mine for about 7k miles with no problems. &nbsp;other alternative is the ACT street disk. &nbsp;very nice grabby clutch slightly heavier than stock pedal feel but not too bad.
Keeping it Godzira bishes.
So I murdered another turbo
Steeles is offline   Reply With Quote
Old 10-03-2002, 02:32 PM   #3
goodjuan
goodjuan's Avatar
goodjuan is an unknown quantity at this point
Send a message via AIM to goodjuan
Do 240s use hydraulicallyy actuated clutches or cable? &nbsp;If they use cable you can temporarily fix the slipping(while your trying to replace it) by loosening the cable. &nbsp;Though if it's a hydraulic, your gonna have to slip till you replace it.
goodjuan is offline   Reply With Quote
Old 10-03-2002, 04:01 PM   #4
bbp
bbp's Avatar
bbp is an unknown quantity at this point
240's have hydraulic clutch systems. &nbsp;Adjustment can be made under the dash, at the top of the pedal. &nbsp;there is a short adjusting rod with a jam nut. Loosen the jam nut and make your adjustment. &nbsp;The pedal play at the top of pedal should be minimal, I think the FSM call for a couple of mm.
BUT, if your car is slipping in 5th gear, the clutch is probably shot. &nbsp;Hydraulic clutches generally do not require adjustment.
You can try it, it will probably need adjusting once you replace the clutch.
bbp is offline   Reply With Quote
Old 10-03-2002, 04:53 PM   #5
sxtasy
Guest
Posts: n/a
Anybody else have any recomendations? I was going to post the exact same question, although I know my clutch is just starting to wear out when I got new tires that are pretty sticky and now instead of the tires spinning........the clutch does <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/hmmm.gif" border="0" valign="absmiddle" alt=':hmmm:'> . It's not really bad now, but the way I drive, it won't take long.
Old 10-03-2002, 06:39 PM   #6
dave240sx
dave240sx is an unknown quantity at this point
Send a message via Yahoo to dave240sx
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">The pedal play at the top of pedal should be minimal, I think the FSM call for a couple of mm.</td></tr></table><span id='postcolor'>
I like the clutch to be down towards the floor more than towards the top of the pedal. &nbsp;Is there a problem with this?
I think it's easier for quick launches with out wheel spin because the clutch engages faster.
-dave-
91 Fastback
--Pilot Shortshifter--
dave240sx is offline   Reply With Quote
