Old 06-12-2007, 11:59 PM   #1
-L(-.O)
-L(-.O)'s Avatar
-L(-.O) is on a distinguished road
sr20det headgasket
quick question. i was told that using a 88.5mm bore headgasket on a stock bore would not be a problem as long as i dont use a headgasket that has a smaller bore than the bore of the block. i was also told that you have to be exact same bore, headgasket and block or it wont last. Everyone has thier own theories but who knows the facts? stock bore is 86mm right?
-L(-.O) is offline   Reply With Quote
Old 06-13-2007, 12:05 AM   #2
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
eh i dont know the answer to the question but stock bore is 86.5mm. ive heard you can use up to 87mm on the stock bore.
benefitx is offline   Reply With Quote
Old 06-13-2007, 06:52 AM   #3
Sileighty_85
Sileighty_85's Avatar
Negitive Dude stock bore is 86mm. well you Dont wanna use a smaller bore HG same size will be fine and also using a slightly lager size is okay (around .5mm) , I bored my Cylinders out to 86.5 and im using a 87mm bore HG.
Old 06-13-2007, 07:31 AM   #4
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
If you are try to go with a 88.5 bore gasket on a stock sr 86mm bore that way too much of a gap. Usually you only go .5 up. If you have a 86 bore, just buy a 86 mm bore gasket. Usually only people who overbore thier cylinders go to a 87 mm gasket. 87 mm would be ok for stock bore but i dont know if I would feel comfortable going to an 88.5 mm gasket.
garagelu is offline   Reply With Quote
