Old 06-23-2007, 03:47 PM   #1
JOEF
JOEF is an unknown quantity at this point
95 S14 Knock, knock, knock?
Someone please help!! My 95 S14 has a distinctive noise/thump/knock coming from the right front that slows as I slow. It only happens under light to medium braking, only going forward, totally gone under heavy braking (or so attenuated you cant feel/hear it). I've got new rotors, pads and calipers all around (no ABS by the way) and when the noise first started I put it up on the lift and the right inner and outer tie rod ends were beyond worn out so I replaced them. I rotated the tires. Still no luck. Would the hub bearing make this happen without making the typical worn out bearing sound at cruising speed? Could the rack be causing this? HELP!!
JOEF is offline   Reply With Quote
Old 06-23-2007, 03:55 PM   #2
tknbkthrsdy4anfg
tknbkthrsdy4anfg's Avatar
tknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfectiontknbkthrsdy4anfg is close to perfection
Send a message via AIM to tknbkthrsdy4anfg
Try looking at the rubber strut insulators on top of the struts, they maybe worn out causing the thud.
Does it by chance make noice when you turn lock to lock?
Originally Posted by Brian
well I suppose you can imagine it like a parking space that you think "gosh, I’ll never fit in there" But then you fold in the side view mirrors and what do you know, your in.
$pending dead pre$ident$ J@CK@TT@CK!
tknbkthrsdy4anfg is offline   Reply With Quote
Old 06-23-2007, 03:58 PM   #3
JOEF
No, no noise while turning only while braking straight on. I thought it may be the rotor catching the pad and causing the noise so I pulled 5 or 6 "panic" stops and the noise went away for about 4 or 5 stops afterwards. Now it's back. I checked the upper strut mounts (while on the car, on the lift, suspension hanging) they seem ok, no play in any direction.
Old 06-23-2007, 04:50 PM   #4
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
Tension rods...your bushings in them are probably shot or they are not tight. If it only happens under braking that's your problem. If you aren't familiar with the vocab, it's the rod that attaches to the front subframe to the control arm.
sean350z is offline   Reply With Quote
Old 06-24-2007, 12:35 PM   #5
JOEF
FOUND IT!!
OK, I'm the stupid one for not checking this during the brake job, but the bottom slider on the right caliper frame was totally grease-less -- BONE DRY -- I took off both front calipers, then frames, cleaned the slider bores and slide pins, greased them and reinstalled everything...NOISE IS GONE!
So, take it from me, the extra 10 minutes it takes to check, clean and relube the sliders is worth it!!
Thanks for the suggestions and Sean, the tension rod bushings were one of my first thoughts too...(mine are in great shape)...Thanks!!
Old 06-27-2007, 08:52 PM   #6
240silviaguy
240silviaguy's Avatar
240silviaguy is a well-known jackass
check to see if the sliders are bent, it most likely will happen again in 10k miles
240silviaguy is offline   Reply With Quote
