Old 07-10-2007, 08:57 PM   #1
Nick240sx
Nick240sx will become famous soon enoughNick240sx will become famous soon enoughNick240sx will become famous soon enoughNick240sx will become famous soon enough
Oh no, my check engine hmmm
ok today i got an oil change, then later on i look and my check engine light is on, what's going on? could it be my oil change? i know im stupid >_>. im not sure if the light went on right after the oil change or a little bit after, but it has been on and has not gone off. can someone help please. the mechanic said he thinks its something with the emissions O_o
http://nickgphotography.org
Nick240sx is offline   Reply With Quote
Old 07-11-2007, 02:12 AM   #2
spinitsidewayz
spinitsidewayz is making a name for him/her selfspinitsidewayz is making a name for him/her self
My engine light would do the same thing sometimes (k24e). But it would turn off after i changed my oil then come back. I would check and i would always get a code 45, leaky injector until i changed my fuel filter, then it came on once then never came back.
Stupid leaky Injector code. Changed the Fuel filter on my dual cam and it did the same shit. Leaky injector code is usually caused by a dirty fuel filter i guess? or at least in my cases.
Go check your fault codes on your ECU and see what it comes up with.
Love:
89 S13 Fastback: Super stock KA24E Daily!
Hate:
89 S13 Coupe: SR20 Under the knife.
87 FC: Half Bridge Turbo Monster.
spinitsidewayz is offline   Reply With Quote
Old 07-11-2007, 05:34 PM   #3
chaser
chaser is an unknown quantity at this point
i've got the same problem at the moment. i checked my ecu and got a 55 saying nothing is wrong. what's the dealio??????
chaser is offline   Reply With Quote
Old 07-11-2007, 05:53 PM   #4
slower than you
slower than you's Avatar
slower than you will become famous soon enoughslower than you will become famous soon enoughslower than you will become famous soon enough
i had the same problem, and it was a leaky injector. but if you dont really give a shit and you just want the light gone for smog, just pop it out cause its obd1 and only visual.
slower than you is offline   Reply With Quote
Old 07-11-2007, 06:12 PM   #5
swayray
swayray's Avatar
swayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfectionswayray is close to perfection
it could be a number of things.... it could also be that you did not tighten the gas cap properly... something went wrong w/ your o2 sensor... etc....
just best to check the light codes the ecu
http://www.thenismoshop.com
swayray is offline   Reply With Quote
