Old 07-29-2007, 09:32 AM   #1
Lucidsnow
Lucidsnow is an unknown quantity at this point
rear scraping sound...help?
ok i recently changed my agx shocks to coilovers... the coilvoers are set slightly lower height then the agx lower springs....
nothing is rubbing in terms of tire/rims/multilink/coilover/exhaust....
after i installed the rear coilovers, when i am driving i now HEAR loud scraping sound from the rear... it sounds like the brake pads are rubbing the rotor ALOT of something... the sound gets louder if i turn my car back and forth ...but when i jacked it up i can still spin the wheel freely by hand...so the pads are floating not pressured
.... i have no idea what is that sound and what the problem is... any ideas?
rotors?pads?hub?bearings?
thanks in advance
Lucidsnow is offline   Reply With Quote
Old 07-29-2007, 10:53 AM   #2
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
have you checked to make sure the afore mentioned parts don't rub when it is OFF a lift?
burgy240 is offline   Reply With Quote
Old 07-29-2007, 11:23 AM   #3
sliddinsil8o
sliddinsil8o's Avatar
sliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enoughsliddinsil8o will become famous soon enough
Send a message via AIM to sliddinsil8o Send a message via Yahoo to sliddinsil8o
wheel bearing maybe
****SIGNATURE EXCEEDS FORUM LIMITS....PLEASE READ THE RULES****
sliddinsil8o is offline   Reply With Quote
Old 07-29-2007, 02:18 PM   #4
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
could it be that your coilovers are rubbing?
lexus baby
5t341tH is offline   Reply With Quote
Old 07-29-2007, 03:15 PM   #5
sikkk240
sikkk240's Avatar
sikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond reputesikkk240 has a reputation beyond repute
Send a message via AIM to sikkk240
Check your dust shield, you could have moved/bent it when you installed the coilovers.
sikkk240 is offline   Reply With Quote
Old 07-29-2007, 10:32 PM   #6
Lucidsnow
it seems its the driver side rear wheel bearing... thanks everyone...
more money into the money pit... weeee
Old 07-29-2007, 10:43 PM   #7
Sean14
Sean14's Avatar
Sean14 can only hope to improve
I may have this same problem on my s13. Is there any way to check and make sure its the wheel bearing and not something else?
Sean14 is offline   Reply With Quote
Old 07-30-2007, 01:17 PM   #8
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
for wheel bearings in the rear put ebrake on and shake/tilt the wheel side to side to check for freeplay. Should be little to none.
Next time try searching for "wheel bearing"
http://www.zilvia.net/f/showthread.p...=wheel+bearing
The link will tell you everything you need to know poste dby R240NA
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 07-30-2007, 01:22 PM   #9
!Zar!
!Zar!'s Avatar
Do as just posted above.
But when you install parts new problems just don't arise the way they did in your case. Unless you just have bad luck.
My bet is you bent the brake dust shield.
