Old 08-01-2007, 12:51 AM   #1
pch
pch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of lightpch is a glorious beacon of light
Send a message via AIM to pch
Hi! Newbie Here
Done, just saying hi. Pictures http://www.zilvia.net/f/showpost.php...postcount=2943 <=Here and intro http://www.zilvia.net/f/showpost.php...&postcount=852 <=here
pch is offline
Old 08-01-2007, 12:57 AM   #2
lil240sx95
lil240sx95's Avatar
lil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfectionlil240sx95 is close to perfection
Send a message via AIM to lil240sx95 Send a message via MSN to lil240sx95 Send a message via Yahoo to lil240sx95
hey that was the OG color of mine sweeeet
but you should go here to introduce..http://www.zilvia.net/f/showthread.php?t=96924
then here for your pictures http://www.zilvia.net/f/showthread.php?t=106249
nice car though
lil240sx95 is offline
Old 08-01-2007, 12:58 AM   #3
unwtdhero
unwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-knownunwtdhero is making his/her stupidity well-known
Nice car but why the s13 sr?
unwtdhero is offline
Old 08-01-2007, 01:05 AM   #4
kdashy
kdashy's Avatar
kdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfectionkdashy is close to perfection
Send a message via AIM to kdashy
Cause hes going for high horsepower?
kdashy is offline
Old 08-01-2007, 01:06 AM   #5
unwtdhero
Werd, fair enough.
Old 08-01-2007, 01:15 AM   #6
pch
one, the car came with it and the second time i choose it because i had the aem ems already and it is only compatible with the sr red top.
nice car though
thanx for the info and i fixed it
pch is offline
Old 08-01-2007, 01:21 AM   #7
pch
So this thread wont be so useless in a sense I will post up a question. I want to pass emissions and I have read the threads about emissions and what not and I have seen what some people have done to pass emission, but usually its on a stock or close to stock SR. In my case, the car is no where near to been stock. I am currently running a 740cc injectors, bigger turbo, blah blah. Anyways, i have gone to emissions i believe a total of 8 times but only have found some of the slips. Here are most of the numbers that I have gotten.
----------------------------------------------------Vehicle's Emissions----------------Standard
retest 2
Hydrocarbons (HC)-----------------------------------.89------------------------------.80
Carbon Monoxide (CO)------------------------------19.94---------------------------12.00
Oxides of Nitrogen (NOX)----------------------------.82------------------------------2.00
retest 3
HC-----------------------------------------------------.91-------------------------------.80
CO-----------------------------------------------------13.43---------------------------12.00
NOX---------------------------------------------------1.43------------------------------2.00
retest 4
HC-----------------------------------------------------1.61------------------------------.80
CO----------------------------------------------------10.00----------------------------12.00
NOX---------------------------------------------------2.86-----------------------------2.00
retest 5
HC-----------------------------------------------------1.20-----------------------------.80
CO----------------------------------------------------11.56----------------------------12.00
NOX---------------------------------------------------3.15-----------------------------2.00
retest 6
HC-----------------------------------------------------.90------------------------------.80
CO---------------------------------------------------17.12----------------------------12.00
NOX-------------------------------------------------3.03-------------------------------2.00
retest 7
HC----------------------------------------------------1.45------------------------------.80
CO---------------------------------------------------1.13-------------------------------12.00
NOX--------------------------------------------------6.19------------------------------2.00
retest 8
Hydrocarbons (HC)-----------------------------------1.38-----------------------------.80
Carbon Monoxide (CO)-------------------------------17.31----------------------------12.00
Oxides of Nitrogen (NOX)-----------------------------1.93-----------------------------2.00
retest 9
hc----------------------------------------------------.89----------------------------------.80
co--------------------------------------------------10.81--------------------------------12.00
nox-------------------------------------------------3.90----------------------------------2.00
Retest 2 was done after I installed a brand new magnaflow high flow cat. Retest 3 was when I intially got rid of the emanage ultimate and went with the aem ems. retest 6 i used an old stock cat and retest 7 is when tony disconnected an injector to see if that would help. All of these test were done when i had the old sr with 850cc injectors. Now retest 8 is the one i just currently did with the 740cc injectors and new sr motor. I am not quite sure were timing is set up or anything of that nature. All i know is that on the last retest i did a new oil change that morning, new spark plugs gapped at .29 i believe or .28, working coil packs, and a high flow cat that Derick let me borrow. I am going for a retune on tuesday with Tony at UMS. I am wondering if you guys can let me know where he should set timing at and what not...any vital information that can assist me in finally passing emissions. Also i think boost is set at 6 or 8 right now, usually its at 16psi. Should i tell him to leave it at that? I know that he is trying to lean it out as much as he can. Is there certain rpms that i should see if he can lean it out the most?
pch is offline
Old 08-01-2007, 02:01 AM   #8
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
PCH,
post in a separate thread... specifically in the tech section regarding your emissions issue since its well... technical.
http://www.zilvia.net/f/forumdisplay.php?f=8
Welcome to the forum tho, just be sure to search before making a new thread about something. If your unsure ask me.
CKAMC is offline
Old 08-01-2007, 02:06 AM   #9
NemeGuero
No more nissan.
NemeGuero's Avatar
Oh Zilvia master, please teach me your ways!
hahaha
NemeGuero is offline
Old 08-01-2007, 02:13 AM   #10
CKAMC
CKAMC's Avatar
hahaha
Ahh thank you Zilvia douchebag.....
CKAMC is offline
