Old 08-03-2007, 01:12 PM   #1
nightshiftgarage
nightshiftgarage's Avatar
nightshiftgarage is on a distinguished road
help with gas gauge have standalone
just notcied that my gas gauge isnt working anymore, thanks to wonderful megasquirt. anyone know how to or have any ideas on how to wire it up on its own without the factory ecu. thanks
nightshiftgarage is offline   Reply With Quote
Old 08-06-2007, 07:05 AM   #2
Matt Cramer
Matt Cramer will become famous soon enoughMatt Cramer will become famous soon enoughMatt Cramer will become famous soon enoughMatt Cramer will become famous soon enough
Post what year you've got, and whether you have a HUD if it's an S13. I'll check the wiring diagrams. On most years, the stock ECU isn't connected to the fuel gauge at all. Do all your other gauges work?
Matt at DIY Autotune
http://www.diyautotune.com
Matt Cramer is offline   Reply With Quote
Old 08-08-2007, 05:59 PM   #3
MegasquirtCA
MegasquirtCA's Avatar
MegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfectionMegasquirtCA is close to perfection
Like Matt said, all the stuff on the cluster except Tach are seperate from the ECU. So megasquirt wasnt the cause it was either it failed or YOU.
It doesnt matter if its analog or HUD I've used both and they all worked fine.
MegasquirtCA is offline   Reply With Quote
Old 08-08-2007, 08:42 PM   #4
sean350z
sean350z's Avatar
sean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of lightsean350z is a glorious beacon of light
Megasquirt will not cause your gas guage to break...
Sounds like a wiring issue seperate from the ECU or your sender is busted.
sean350z is offline   Reply With Quote
Old 08-17-2007, 06:00 AM   #5
nightshiftgarage
matt. its a 97 .
other dudes, i didnt think ms broke my gauge
my car had some weird electrical meltdown, thats when i decided to do ms.now i cant get the ms to communicate with the laptop. im using a usb cable to comm port.it just seems like its been one thing after another.getting a lil frustrated.
Old 08-17-2007, 07:31 AM   #6
the head
the head's Avatar
Originally Posted by nightshiftgarage View Post
matt. its a 97 .
try assignng a specific com port to the USB in your computer settings I had that issue with my Haltech initially because the USB was COM 27 on my system and the Haltech can only support single digit COM assignments.
Old 08-18-2007, 04:46 PM   #7
nightshiftgarage
i didnt know the cable cane with a cd to load. after that its been good. still have no tach signal and or spark tho.
Old 08-20-2007, 08:10 AM   #8
Matt Cramer
On this model, the fuel gauge just wires straight to the sending unit. Check to see if you're getting a voltage at the sending unit from the gauge.
You won't get a spark until the Megasquirt gets an RPM signal. Does the Megasquirt work on a Stim?
Old 08-31-2007, 02:27 PM   #9
nightshiftgarage
if thats something extra, mine didnt come with that
Old 09-04-2007, 12:48 PM   #10
Matt Cramer
It's an extra diagnostic board. Without it, the first thing to check is if it's getting a signal in at pin 24 that is going from 0 to 12 volts and back again as the distributor turns.
