Old 09-01-2007, 11:26 PM   #1
cyclone92692
cyclone92692 is a well-known jackass
sr heats up during constant boost
when driving at 12lbs of boost, stock motor, it tends to increase the motor temperature. my water/ coolant gauges climbs near 250 degrees as well as the oil temperature reaches over 180 degrees and my regular temp on dash gauge starts to climb near the H mark. i have an upgraded radiator and electric fan, in working condition. anyone know how i can decrease engine temperature under heavy load.
P.S car runs perfect when driving normal. only begins to heat up when i romp on it alot. any help is appreciated.
cyclone92692 is offline   Reply With Quote
Old 09-02-2007, 01:00 AM   #2
Bizzytony
Bizzytony is on the path to ruinBizzytony is on the path to ruin
those radiator block plates, that keep air from going over the top work good. also if you dont have the plastic undertray that helps too.
Bizzytony is offline   Reply With Quote
Old 09-02-2007, 01:22 AM   #3
drift-it
drift-it's Avatar
drift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-knowndrift-it is making his/her stupidity well-known
Send a message via AIM to drift-it
run nismo thermostat, or no thermostat
drift-it is offline   Reply With Quote
Old 09-02-2007, 04:44 AM   #4
Koopa Troopa
Koopa Troopa's Avatar
Koopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfectionKoopa Troopa is close to perfection
Send a message via AIM to Koopa Troopa
I'm guessing your headgasket sucks or your head might be lifting...
Buy my Stillway shifter!
Koopa Troopa is offline   Reply With Quote
Old 09-02-2007, 01:06 PM   #5
xpl2007
xpl2007's Avatar
xpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfectionxpl2007 is close to perfection
NO get a good radiator "KOYO" Blocking plates bottom and top, Blitz Radiator cap, Water Wetter, Electric fan or fans, check water pump, and your good...
Have the same problem and this is the fix...
Theres a test do a search its a pretty good test on it all.
jeff
http://zilvia.net/f/traderratings.html?u=57636
If i sold you something or gave you it for free post here! Thanks!
xpl2007 is offline   Reply With Quote
Old 09-02-2007, 02:09 PM   #6
cyclone92692
jeff
so where can i buy blocking plates and what do they look like. I dont understand what these blocking plates are and how do they help my engine run cooler. just curious not doubting it just want to learn. plus what shouyld i type to search the test
Old 09-02-2007, 03:22 PM   #7
motegineon
Banned from the Marketplace
motegineon's Avatar
motegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond reputemotegineon has a reputation beyond repute
Send a message via AIM to motegineon Send a message via MSN to motegineon
im assuming its your headgasket if u still have a stock one..
im having the same problem, im running a koyo radiator, nismo thermostat, metal headgasket, dual electric fans, blocking plate, greddy fmic, and like 80% water + water wetter...and my temp runs up too..the car is eating a crapload of coolant and i cant figure out where from since im running a metal headgasket im assuming its not that??? if someone can help me too thatd be great
motegineon is offline   Reply With Quote
Old 09-02-2007, 08:15 PM   #8
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
+2 for sounds like the headgasket.
@woooster on instagram
kuruptR is offline   Reply With Quote
Old 09-02-2007, 08:29 PM   #9
cyclone92692
Excuse me but i'm a little confused here, why would you tell me that it may be my stock head gasket if you are using a metal head gasket and are experiencing the same issue. by the way if it was my headgasket then the problem will be alot more severe i'm assuming... my car overheats only under hard driving conditions. please post only if you have experience on this matter, not jibber jabber....
Old 09-02-2007, 08:37 PM   #10
!Zar!
!Zar!'s Avatar
lol koyo fails at a radiator.
But whatever.
Check your water pump. Maybe it's cavitating or going out.
Replace your thermostat. Don't remove it. Yes it might fix your problem but it also can potentially fuck your motor. SWEET!
Adding dew-dads and what not won't fix his problem. And suggesting such is stupid. Have your motor leakdown tested. Because something is obviously wrong.
Damn. Don't hate. An option was being given to you and you post messy shit. UGH.
I guess you missed the other post about someone stating that your head could be lifting huh?
Ugh. Metal headgaskets.
Old 09-02-2007, 08:45 PM   #11
cyclone92692
i didnt miss the post about the head lifting just not familiar with that condition. how does a head lift? by the way sounds like all SR20s have this overheating issue, so do all the jdm silvia have this issue from the factory?
Old 09-02-2007, 08:56 PM   #12
92_570sx
92_570sx's Avatar
92_570sx is an unknown quantity at this point
This sounds stupid but make sure your coolant has a good mix. Too much coolant will keep to much heat and not cool as good.
92_570sx is offline   Reply With Quote
Old 09-02-2007, 09:14 PM   #13
cyclone92692
hmmmm never heard of that!!!
Old 09-02-2007, 09:24 PM   #14
Fat Felix
Fat Felix is on a distinguished road
Send a message via AIM to Fat Felix
stop being a noob and listen to Zar. leakdown test first because you may find your biggest problem first.
koyo al. radiators have been good to me, even at the track(desert) in the begining of summer. no need for electric fans, clutch fan works fine. the fan doesn't do shit after the gets moving anyways. and water wetter, a splash of coolant, and the rest water has worked great for me.
megasonly.wordpress.com
Fat Felix is offline   Reply With Quote
Old 09-02-2007, 10:00 PM   #15
cyclone92692
leakdown it is then!!!
Old 09-02-2007, 10:01 PM   #16
cyclone92692
leakdown it is then!!! i have the proper tools.
Old 09-03-2007, 01:18 AM   #17
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
What they mean by blocking plate is if you look on top, there that open gap between your front mount and your radiator. Air has a tendency to go thru the fmic and then go to the least resistance of a path. Itll go over the top of the radiator or under. So you get a piece of sheetmetal from Home depot, place it under and get a cooling panel specific to the chassis for the top. They you can can some foam cutouts and stuff it on the sides to make sure as much air as possible is being diverted INTO the radiator instead of around it.
Then, flush your cooling system, changed your thermostat to colder ones and double check your water pump and make sure its fubared. It doesnt have to be leaking to be bad. The fins could be corroded and not circulating coolant enough. Then depending on where you at, distilled water, water wetter and a dash of coolant help with cavitation and lubrication. Also, change your rad cap.
PS: YOU DO HAVE A FMIC RIGHT?!?!
CLICK HERE!!!
Old 09-03-2007, 11:21 AM   #18
motegineon
motegineon's Avatar
yes excuse you, your right i dont have experience, i havent already blown my stock headgasket and replaced it with a metal one ...what i am experiencing is overheating over driving for a certain amount of time, regardless of boost or not. Since i have a metal headgasket and only boost up to 15psi the chances of mine being blown are far slimmer than yours...when i had a stock headgasket it drove fine but once i boosted then it wanted to overheat, which sounds a lot like what your experiencing..but hey what do i know..
Old 09-05-2007, 10:21 AM   #19
Koopa Troopa
I can't explain the science of why it lifts, maybe try google or wikipedia.com...
Maybe it's lifting due to a compression leak or bad head studs or both, I dunno. Like someone said before get a leakdown test done. Replace your headgasket and get some ARP head bolts.
Silvias don't have an overheating problem, they just have airflow problems.... Go buy some sheet metal at a DIY store and build some ducting.
Oh, I assume you're running a red top SR which means your motor is older than dirt. SR water pumps love to corrode.... I'da replaced all that shit before I installed the motor but live and learn. I'd send you a semi-new water pump I have but I'm not going to be home anytime this year.. Sorry.
Oh I almost forgot.... You're oil temps are rising? Change your oil! I can only imagine how old that oil must be...
Old 09-05-2007, 05:57 PM   #20
cyclone92692
Ok so i did a leak down test and everything reads fine. so i bought this car 3 weeks ago with such general knowledge on SR20 motors. after some questionning and research, I have comne to notice that my car has only one electric fan on the radiator mount in the middleon my fan (looks a little mickey mouse set up) and my FMIC is totally blocking air into my engine bay. so next step is to check out what type of electric fan i have and the rate of CFM and maybe cut out some vent opening or make some ducts like the post guy mentioned.
Old 09-05-2007, 06:00 PM   #21
cyclone92692
oh ya by the way my motor is a blacktop, and i bought the car already swaped. I did check the water pump, it spins pretty freely and my thermostat works my hoses are good. but i do have airflow restrictions BIG time. thank you guys for your help. BRB
Old 04-17-2008, 10:37 PM   #22
mifesto
mifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nicemifesto is just really nice
oil cooler will help..... i dont know where you live but you can try adjusting your radiator fluid/water ratio .... from 50/50 to like 30/70. water will drop the water temps guaranteed. also get a vented hood possibly and maybe upgrade ur fan to a stronger one.
mifesto is offline   Reply With Quote
Old 04-18-2008, 12:52 AM   #23
motegineon
motegineon's Avatar
post is like 7 months old lol
but yea sure
