Old 03-06-2007, 11:47 AM   #1
Dopefish
Dopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really niceDopefish is just really nice
Send a message via AIM to Dopefish
R33 Gauge Cluster in S14
I attempted to do this installation via the guide listed on NICO.
http://img.photobucket.com/albums/v2...s14_wiring.jpg
However, there are inconsistancies with which plug, what color and the number of wires listed as well as some wires on either end (cluster or car) are not listed at all.
I currently have the following signals connected, according to the guide listed above, I also varified most of them by following the traces on the blue circuit board.
GRND (2 wires)
2P (2 wires)
IGN
FM
T/R
T/L
TM
TAM
ILL + (2 wires)
ILL - (2 wires)
...now the speedometer still does not function, and I cannot figure out why, it doesnt budge at all. Everything else seems to work wonderfully though, that I have wired up. Right now I'm just working on the gauges, the indicator lights will come next. I already adjusted my tach as well for the KA engine but the speedo still ignores me. I am thinking if dicecting my S14 cluster and using my speedo mechanism on the R33 cluster, just in case the R33 one is actually bad. Then just adjust the resistors in back to compensate for 180mph instead of 120mph.
Any ideas on why my speedo still hate me?
Car is a 95' S14 base and cluster is from a 95' R33 GTS-t
Thanks,
_Kris
It never got fast enough for me. -Hunter S. Thompson
Dopefish is offline   Reply With Quote
Old 03-06-2007, 11:59 AM   #2
Dopefish
Double post.
Old 03-06-2007, 12:24 PM   #3
Dopefish
Here are the inputs I've deciphered as to their purpose.
GRND - Ground (Common grounds)
2P - Speedometer (Input signal, speedometer gauge) [2 WIRES]
BAT - 12v Constant (For S14 in-cluster clock)
IGN - Ignition
FM - Fuel Meter (Input signal for fuel gauge)
CHG - Charge (Indicator, charging/battery issue)
T/R - Turn Right (Indicator, right)
T/L - Turn Left (Indicator left)
TM - Temp Meter (Input signal for coolant temp gauge
BRK - Brake (Indicator, lamp for brake issue/brake lamp failure)
FUEL - Fuel (Indicator, low fuel)
BEAM - Brights (Indicator, high beam headlamps)
TAM - Tachometer (Input signal, tachometer gauge)
BELT - Seatbelt (Indicator, driver seatbelt not secured)
OIL - Oil (Indicator, low oil)
AIRBAG - Airbag (Indicator, restrainsystem complication)
DOOR - Door Ajar (Indicator, open door)
Check ENG - Check Engine (Indicator, ODBI/II complication)
ILL + - Illumination + (Positive voltage for dash lighting circuit) [2 WIRES]
ILL - - Illumination - (Negative voltage for dash lighting circuit) [2 WIRES] {Two specific ground wires}
EXH - Exhaust Overheat (Indicator, abnormal temp of catylst)
OM - Oil Meter (Input signal for oil pressure gauge)
WASH - Washer Fluid (Indicator, low washer fluid)
Still unsure of the purpose behind the Ignition connection... it seems to correlate with the speedometer, which might be part of my issue.
Asside from that, the airbag lamp is constantly illuminated, even though I don't have the airbag indicator wired to the gauges yet... (Possible short somewhere?)
_Kris
Old 03-06-2007, 12:42 PM   #4
DaPCWiz
DaPCWiz's Avatar
DaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond reputeDaPCWiz has a reputation beyond repute
Send a message via AIM to DaPCWiz Send a message via MSN to DaPCWiz Send a message via Yahoo to DaPCWiz
The image link is broken...
http://blog.dapcwiz.com
DaPCWiz is offline   Reply With Quote
Old 03-06-2007, 12:57 PM   #5
sbanzer123
sbanzer123's Avatar
sbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the rough
ya fix the link i really want to see pics of this for some reason.
sbanzer123 is offline   Reply With Quote
Old 03-06-2007, 03:08 PM   #6
forum04pl
forum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond repute
Send a message via AIM to forum04pl
+1 for the link im really trying to see this
forum04pl is offline   Reply With Quote
Old 03-06-2007, 04:28 PM   #7
Dopefish
Link rehosted:
Wiring:
_Kris
Old 03-06-2007, 04:38 PM   #8
cmcdougle
cmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to beholdcmcdougle is a splendid one to behold
Send a message via MSN to cmcdougle
A writeup when you're done would be wonderful. I am looking to do this in my car soon. . .
cmcdougle is offline   Reply With Quote
Old 03-06-2007, 04:45 PM   #9
Akiros
Akiros's Avatar
Akiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfectionAkiros is close to perfection
Send a message via AIM to Akiros
what does it look like all lit up?
edit: wonder if you can find the nismo white faces?
Akiros is offline   Reply With Quote
Old 03-06-2007, 04:54 PM   #10
Dopefish
http://memimage.cardomain.net/member...12_10_full.jpg
Edited with pics of them on, they are working great in exception to the speedo and the airbag light issue.
There was actually a GT-R assembly on eBay with the 11k NISMO tach not too long ago, it went for over $300 though. :/ I'm not too fond of white face gauges to be honest anyways, so I'm content with the GTS-T version.
_Kris
Old 03-06-2007, 04:59 PM   #11
dct223
dct223's Avatar
dct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nicedct223 is just really nice
Send a message via AIM to dct223
looks great!
Sfourteen
dct223 is offline   Reply With Quote
Old 03-06-2007, 10:40 PM   #12
Akiros
Akiros's Avatar
wow, im diggin that. looks neat.
Old 03-06-2007, 10:49 PM   #13
mattack69
mattack69's Avatar
mattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enoughmattack69 will become famous soon enough
Send a message via AIM to mattack69 Send a message via MSN to mattack69 Send a message via Yahoo to mattack69
s14 !!!
NO FUCKING WAY!!! They dont even show you how to hook up your washer lines on the link he has!!!!! Gheymer Sorry man that was the funniest thing on this thread. My bro-in-law is gonna get with his peeps and get you an answer on that but you seem to be going in the first direction I could think of just remember to splice lightly daniel-son and you get some love added to your reputation the write up would help a lot of peeps out man dont let them stay in the dark.
mattack69 is offline   Reply With Quote
Old 03-07-2007, 09:51 AM   #14
projectRDM
projectRDM's Avatar
Try that again in English please.
Old 03-07-2007, 12:03 PM   #15
cmcdougle
Yes, please.
That looks sick put into the car. I am doing this for sure. Do the holes line up right with the dash, or does it just squeeze in?
Old 09-02-2007, 03:08 AM   #16
Dopefish
I never updated this and I apologize. There are a couple colors that are the same so you have to be careful when splicing it all together. The airbag light is taken care of after a rewire as was the speedo signal.
I'm having some bodywork done but once I get the car back I'll document the pinouts and which connector they come from to ease the pain of potentially mixing up wires.
Old 09-02-2007, 10:16 AM   #17
Unholy S14
Unholy S14's Avatar
Trader Rating: (-3)
Unholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfection
Feedback Score: -3 reviews
Send a message via AIM to Unholy S14
wow amazing.
good job
parting out dark blue 89 hatch, PM me if you need anything.
Unholy S14 is offline   Reply With Quote
