Old 10-20-2002, 10:56 PM   #1
luke91
luke91 is an unknown quantity at this point
Aside from replacing the pistons and rods, does anything else need to be reinforced, or replaced?
Does the engine require any block work?
--luke
'91 fastback.  '97 S13 blktop SR20DET.  Cstm Frnt Mnt IC w/ cstm 2 1/2" piping.  stnls stl fltr.  3" cstm DP & exhst w/N1 muff.  Walbro FP.  ACT 6 pck cltch.  Go Fast Bits crnk plly.  Ground Control coils.  KYB AGX shks.  12.98@106 w/g-tech pro.  17psi.  All work and fabrication done by ME
luke91 is offline   Reply With Quote
Old 10-21-2002, 10:10 PM   #2
luke91
I know one of you know this.
--luke
Old 10-22-2002, 12:07 AM   #3
DSC
New Title
DSC is an unknown quantity at this point
umm, yeah. &nbsp;what else is in the bottom end? &nbsp;Yeah, replace or reinforce it <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/wink.gif" border="0" valign="absmiddle" alt=''>
Pretty broad question though. &nbsp;Building the SR for what exactly? &nbsp;You can always ballance the crank. &nbsp;I know there's treatments and stuff for it, but I dono what. &nbsp;Bearings and stuff too.
DSC is offline   Reply With Quote
Old 10-22-2002, 10:14 AM   #4
fast-datsun
fast-datsun is an unknown quantity at this point
If your planning on running High boost the block need sleeved to ensure cylinders are round.. contack Mckinney Motorsport for custom sleeves and installation..
fast-datsun is offline   Reply With Quote
Old 10-22-2002, 12:52 PM   #5
sykikchimp
WOW addicted
sykikchimp's Avatar
balancing, blue printing, shot peanning, etc.. tons of procedures to sure up the bottom end.. you can buy forged pistons, rods, and cranks if you want. good thing for you is the Crank, and rods are forged from the factory on the SR. Pistons are cast. Resleeving the block would help in extreme situations.. The SR has been proven time and again to be good in stock form to over ~400hp.
If you want specific answers try to be a bit more specific in your questions.. &nbsp;such as goals, current situation, why you looking into rebuilding, etc..
Old 10-22-2002, 10:25 PM   #6
luke91
OK, I'm planning on making 4000whp. &nbsp;
J/K.
I'm just building it up for about 450-500 whp. &nbsp;
This won't be for a while, though. &nbsp;I'm already planning on
pistons and rods, and balancing the whole rotating assembly. &nbsp;
I'm trying to avoid block work, like cylinder sleeving. &nbsp;
Is this really necessary? &nbsp;
--luke
'91 fastback. &nbsp;'97 S13 blktop SR20DET. &nbsp;Cstm Frnt Mnt IC w/ cstm 2 1/2&quot; piping. &nbsp;stnls stl fltr. &nbsp;3&quot; cstm DP &amp; exhst w/N1 muff. &nbsp;Walbro FP. &nbsp;ACT 6 pck cltch. &nbsp;Go Fast Bits crnk plly. &nbsp;Ground Control coils. &nbsp;KYB AGX shks. &nbsp;12.98@106 w/g-tech pro. &nbsp;17psi. &nbsp;All work and fabrication done by ME
Old 10-23-2002, 10:11 AM   #7
wherezmytofu
wherezmytofu is an unknown quantity at this point
a...the engine deamons have called me back..... <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
450-500whp will take sum work, but not hard in a sr20det...
-iron ductil sleeves
-copper head gasket, thicker then stock <--u can get one in any local machine shop
-forged connection rods, pistons...pick the compression ratio that will wokr with ur psi, so u can drive it on the streets...on like 91 octane...hahahah
-aftermarket bearings
-larger oil pan
-block brace, i rember sum1 making one for the sr20, its a reinforment that goes in the oil pan area to strenghten aluminum blocks <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''>
-arp bolts, all over
then of course u need to do sum simple things like:
balance the crank, knife edge it, polycoat it or micro polish it...actually u should poly coat or micro polish the crank, connection rods and pistons...if u dun do the pistons...at least sand them down a bit.
doing all that u should be able to run 800h[ savely &nbsp; <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/laugh.gif" border="0" valign="absmiddle" alt=':laugh:'>
wherezmytofu is offline   Reply With Quote
Old 10-28-2002, 11:19 PM   #8
luke91
OK, the only obvious problem to me is that ARP does't make studs or bolts for the SR20. &nbsp;
--luke
Old 10-29-2002, 12:50 AM   #9
Itsuki
Itsuki's Avatar
Itsuki is an unknown quantity at this point
I would go with JUN Head and main crank bolts...
Itsuki is offline   Reply With Quote
Old 10-30-2002, 01:13 AM   #10
luke91
thank you
--luke
Old 10-30-2002, 02:43 PM   #11
jupiterl
jupiterl's Avatar
jupiterl is an unknown quantity at this point
Send a message via ICQ to jupiterl
Do we have to balance the crankshaft when I put in new forged pistons and rods ?
SR20det redtop, 205hp Stock
jupiterl is offline   Reply With Quote
