Old 09-16-2007, 08:55 AM   #1
S14-Turbo
S14-Turbo is an unknown quantity at this point
Ka24det Advice Needed !!!
What do you think of these specs ?
Greddy emanagement
Greddy RS bov
turbo timer
boost controller
b&m shifter
AEROMOTIVE fuel pressure regulator
walbro fuel pump
300zx fuel filter
sr20det 370cc fuel injector
t70 turbo
300zx LSD, 300zx Aluminum 4 piston Brake Caliper upgrade
Full 3 inch APEXi exhaust system
HID
Its tuned to 230rwhp at 8 psi... Reliable ? something needed ?
This Car is going to be daily driven to and from school, then work, and to local car clubs... Will it last ?
S14-Turbo is offline   Reply With Quote
Old 09-16-2007, 09:30 AM   #2
aznrib
aznrib is making a name for him/her selfaznrib is making a name for him/her selfaznrib is making a name for him/her self
you can find alot more information on ka-t.org.
aznrib is offline   Reply With Quote
Old 09-16-2007, 10:04 AM   #3
1985zcar
1985zcar's Avatar
1985zcar is making a name for him/her self1985zcar is making a name for him/her self
Send a message via AIM to 1985zcar
T70 turbo? And you're only going to use 370cc injectors? That's a little on the stupid/risky side isn't it?
370s are usually used with T25/T28s...
1985zcar is offline   Reply With Quote
Old 09-16-2007, 10:16 AM   #4
S14-Turbo
LoL, its already put together.. and tuned to 8 psi.. Ive been told by plenty to change injectors and so i shall... probably goto 550's.. but what i ask is do you think it will last ? its gonna be my daily driver
Old 09-16-2007, 12:46 PM   #5
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
more like 700cc..
ch1873857 is offline   Reply With Quote
Old 09-16-2007, 01:03 PM   #6
murda-c
murda-c's Avatar
if the tune is good and that t70 doesn't creep it should last.
Old 09-16-2007, 01:13 PM   #7
S14-Turbo
it holds 8 lbs nicely.. i think i might change the injectors to 550cc... would i have to Tune the car again ?
Old 09-16-2007, 08:32 PM   #8
ch1873857
yeah.. your injectors are just limiting your power levels. you fine now at that power. 550s will be good for maybe 400.
Old 09-16-2007, 09:05 PM   #9
Irukandji
TUNE TUNE TUNE
Sell the t70 and get a t28
don't skimp out on that. If you don't plan to spend good money on a good tune, don't even bother attempting this.
Irukandji is offline   Reply With Quote
Old 09-16-2007, 09:14 PM   #10
EDacIouSX
EDacIouSX's Avatar
Trader Rating: (53)
EDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfectionEDacIouSX is close to perfection
Feedback Score: 53 reviews
if you change injectors you will need a tune. Why? because the computer will tell the injector to open at 50% when 50% open on a 370 is a lot different than 50% on a 550. i'm no engine expert though. and also, i don't see why 370cc should be bad with a t70? Won't the 370cc injector only LIMIT the amount of power it will put down?. And also, if its a good tune it should be fine. as long as you don't change anything you won't need a retune... IE sell the t70 and go to a t28. You'll def need another tune for that.
Old 09-21-2007, 08:47 AM   #11
S14-Turbo
1st off wow at your avatar.. secondly i agree because im not shooting for any higher power.. i jus want a daily driver.. turn down for me is that i take the turnpike to school and will be tempted to boost 8-/.. and boost some more...
Old 09-21-2007, 09:15 AM   #12
akuma s14
akuma s14's Avatar
akuma s14 is making a name for him/her selfakuma s14 is making a name for him/her self
Originally Posted by n1sm0r View Post
TUNE TUNE TUNE
nice tip on tuning... I agree with you there. As far as putting a T28 on a KA 24?
WHY????? That turbo will barely flow enough on a 2.0 liter. The T28 will not make much power, might help a little on the spool but you'll be at 230-250 hp range all day no matter what injector you use. I recommend a turbo that moves a larger volume of are at a lower psi.
Sure a T28 can make 350 hp at 28psi or whatever, but KA engine will not hold that kind of psi - with out major work.
BTW I use stock injectors and a BEGI fpr with a t04b in combo to make 258rwhp at 8 psi. No tuning/afc/etc needed. just a good old fashioned wide band o2 sensor and a fuel pressure gauge.
Terry
AKUMA WORLD
Drift Buffet
akuma s14 is offline   Reply With Quote
