rb25 s13 swap - harness hookup question -help?
hey,
i just dropped my rb25 in, relocated the battery to trunk, hooked it up to the starter, and started hooking everything up, (ecu, dash, trans, spark plugs, etc) but my problem is that nothing on the interior works, as if no power getting to it (the dash harness IS connected), is this because theres no plugs that are connected to main fuse box in the engine bay? if so, i cant find any that connect to it, my harness was wired by syko performance, but no plugs fit the fuse box plugs. and even if they dash harness was working, when i go to start the car nothings going to happen. i know that its probably some stupid solution, but i hate wiring, so i need help thnks
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
Ya the wire from the alternator goes to a 75 amp main fuse which also powers up the interior fuse box so you need to run your charge wire through the underhood fuse box.
![]() Join Date: Jan 2007
Yup check the 75 amp fuse that will cause it. It cost like $16 and you have to get it from nissan. All your connections should fit cause they only change a couple wires.
As mentioned in the first post, you probably don't have power feeding the main fuse box. Please contact our tech support if you continue to have problems. Should be an easy fix.
-Syko Performance |
alright, Ive been really sick, so i havent had a chance to look at it again, but im goin to give syko a call and see what they can do.
