Old 10-29-2002, 09:20 AM   #1
sil80
sil80 is an unknown quantity at this point
I am leaking coolant out of the front of the engine and wondering if I should just pull the water pump off and redo the seal or replace the whole water pump(KA24DE). Should I replace anything else while im at it?
Five degrees of separation - from you and your license
91 240sx SE
sil80 is offline
Old 10-29-2002, 09:43 AM   #2
red240ne
red240ne is an unknown quantity at this point
if you're doing that you might as well do thermostat and gaskets, you could get all that for 20 bucks probably.  you might as well replace all heater and radiator hoses while you're at it as well, so you can get that whole headache out of the way.  they are a bitch to get off if you're car is 10+ years old, so you might as well just do it all in one day.
nebraska sucks
red240ne is offline
Old 10-29-2002, 04:09 PM   #3
camppain
Will never get banned...
camppain's Avatar
camppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enoughcamppain will become famous soon enough
Send a message via AIM to camppain Send a message via MSN to camppain Send a message via Yahoo to camppain
is the coolant coming from the front cover or the water pump?
if its the front cover while you have that off you should do your t chain if your up on miles.
if its the water pump then replace it if your engine has alot of miles its not worth doing the job twice unless you like turning wrenches ever few months for the same problem.
-=-99 Sentra SE 5 speed-=-
-=-95 240 SE 5 speed-=-
camppain is offline
Old 10-29-2002, 08:50 PM   #4
misnomer
misnomer's Avatar
misnomer has a little shameless behavior in the past
Send a message via AIM to misnomer
Water pump is cakewalk to reseal. &nbsp;I spent more time getting the belt off than pulling the pump <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=''> I just resealled mine, there wasn't any play in the shaft, still spun smoothly. Saw no reason to replace it.
Rowsdower saves us and saves all the world!
misnomer is offline
Old 10-31-2002, 04:56 PM   #5
philipwight
philipwight is an unknown quantity at this point
there is a seep hole at the bottom of the water pump that goes out and that is usually what goes wrong with the pump. &nbsp;When you have the water pump out look at the bottom of it and there is a hole in the housing and if that hole has calcium deposits around it then most likely the pump is bad and you need to get a new one. If you want to save yourself the 20-30 for a cheap a waterpump then take the water pump out and put a new seal on it(use the clear rtv) and put it back fill it up and see if you can see water leak out. If you do this make sure that the area you apply any silicone to is very dry.
philip
1993 Nissan 240sx
-KAAZ 2-way
-crystal clear H4 upgraded lights
-sportline springs-tokico blue struts
-(1)JL audio 12w3 in bandpass box-Rockford 500x-Infinity 4x6
-clarion Rdx765Dz head unit
philipwight is offline
Old 10-31-2002, 05:06 PM   #6
wherezmytofu
wherezmytofu is an unknown quantity at this point
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote (camppain @ Oct. 28 2002,6:09)</td></tr><tr><td id="QUOTE">is the coolant coming from the front cover or the water pump?
if its the water pump then replace it if your engine has alot of miles its not worth doing the job twice unless you like turning wrenches ever few months for the same problem.</td></tr></table><span id='postcolor'>
U GOT A DELL.....DUDE! &nbsp;<img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/biggrin.gif" border="0" valign="absmiddle" alt=''>
wherezmytofu is offline
Old 08-04-2008, 07:58 PM   #7
CityHunt3R
CityHunt3R's Avatar
CityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to allCityHunt3R is a name known to all
will you hear knocking noises if the water pump is bad?
CityHunt3R is offline
Old 08-04-2008, 09:57 PM   #8
Nolmack
Nolmack is on the path to ruinNolmack is on the path to ruinNolmack is on the path to ruin
Hey, if your leaking from your water pump, you can check by looking underneath the water pump for a hole, if you see that hole is leaking with coolant, time for a new water pump. But if your going to replace water pump i totaly agree with what red24one and camppain said, and replace the thermostat and gaskests.
Nolmack is offline
Old 08-05-2008, 02:53 AM   #9
ericcastro
ericcastro's Avatar
dont think so.
but technology in 2002 was different.
old thread guys, really old. lol. Im actually surprised someone was able to dig this up
ericcastro is offline
