Old 09-25-2007, 09:34 PM   #1
benefitx
Banned from the Marketplace
benefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choicesbenefitx has made poor choices
T28 Question
so i just bought this turbo
http://www.zilvia.net/f/showthread.php?t=155740
will i need to use a oil restrictor? i mean if its coming off an sr20det blacktop , do they have stock oil restrictors in the block or what? or is it in the turbo...
oh and is that turbo an s14/s15
benefitx is offline   Reply With Quote
Old 09-25-2007, 10:11 PM   #2
S14GE
S14GE is making a name for him/her selfS14GE is making a name for him/her selfS14GE is making a name for him/her self
SR
If the T28 was pulled off an S14 SR, you are going to have to determine whether or not the turbo is ball bearing by looking at the serial numbers on the turbo. The stock T25 turbo lines from the S13 SR will not fit without modification, so Stainless Steel turbo lines would be the route you should take-still leaving you with one more option. Since the T25 from the S13 SR is not ball bearing, you can use your stock banjo bolts only if you have determined that your T28 is NOT ball bearing. If it is ball bearing you will have to do away with the stock banjo bolts, get a fitting on one end of the line that fits on the block, and the oil restrictor on the other end which threads right into the turbo. BTW, stock thread on the S13 SR BLOCK is 12x1.25 METRIC (thread of S13 stock banjo bolt.) Does that make any sense?
IT IS an S14 Turbo- no split on the back of the turbine housing between the flapper door, and the turbine wheel.
www.takamotorsports.com
go to products> restrictor fittings>
Putting a restrictor on your turbo, is done to regulate oil PSI to prolong the life of your turbo, because higher engine speed means greater engine oil PSI. TOO much oil in your turbo can lead to a blown seal, and the only way to diagnose the problem is oil coming out of the compressor housing, or oil burned out the turbine down the exhaust. Ball bearing turbo's are not rebuildable- so DO YOU NEED A RESTRICTOR? YES it's better to be safe than sorry spending $12 or so on a restrictor sounds a lot better than throwing away $400-500 on a turbo.
SEARCH. SEARCH. SEARCH.
hope this helps...
S14GE is offline   Reply With Quote
Old 09-25-2007, 10:18 PM   #3
benefitx
i already bought taka lines...ok i guess ill get a restrictor, do i need .06 or .03..
and that is a BB turbo..
and why would i need to run an aftermarket oil restrictor if it is a stock turbo?
Old 09-25-2007, 10:32 PM   #4
S14GE
S13 T25 turbo- non ball bearing
if yours is ball bearing, get the ball bearing restrictor- .03
Old 09-25-2007, 10:38 PM   #5
benefitx
well the .06 says t25/t28...
the .03 is for the gt series..
Old 09-26-2007, 07:26 AM   #6
Sileighty_85
Sileighty_85's Avatar
Cuz the Stock restrictor is built in to the Banjo Bolt so when you run SS Lines they dont have restrictors in them so you have you buy them for your setup
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 09-26-2007, 08:04 AM   #7
benefitx
oh ok...thanks
.03 or .06
Old 09-26-2007, 08:34 AM   #8
benefitx
i just sent payment for the .06...can someone chime in because if its the wrong one i can still change it...i e-mailed taka anyways
Old 09-26-2007, 01:55 PM   #9
PhilthyS13
PhilthyS13's Avatar
PhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfectionPhilthyS13 is close to perfection
I'm doing the same thing and I emailed Harp and he told me .06.
PhilthyS13 is offline   Reply With Quote
