Old 10-02-2007, 03:46 PM   #1
steve_o1989
steve_o1989's Avatar
steve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond reputesteve_o1989 has a reputation beyond repute
Car Won't Start
Well I had this problem about 3 weeks ago. I went to start my car, started for about 1 second and then died and wouldnt start again. It ended up sitting for close to 2 weeks as I was busy. First though was fuel pump. I disconnected a fuel line and put it into a bottle, crank the engine over, and the car starts (burning what was left in the fuel rail) Also, the bottle fills so I know that the fuel pump is working. Put the fuel line back on, crank it over, and it starts right away. Let it sit to charge then I changed the battery terminals and it was good to go.
Well, today after school, the exact same thing happened. Except the car didn't really start before it died. It just sits there and cranks, but nothing. I am stuck for ideas. I am going to go change the plugs on it and see if I get anything, but what else should I check. Last thing I need is my car dying on me everyweek leaving me stranded somewhere.
The car is a 1990 Nissan 240sx. Ka24e, with about 30k on a rebuild. Engine is stock other than some MSD wires and a ricer air filter.
steve_o1989 is offline   Reply With Quote
Old 10-02-2007, 06:48 PM   #2
whiteytighties
whiteytighties has a spectacular aura aboutwhiteytighties has a spectacular aura aboutwhiteytighties has a spectacular aura aboutwhiteytighties has a spectacular aura aboutwhiteytighties has a spectacular aura aboutwhiteytighties has a spectacular aura about
Make sure your cables are tight on your battery terminals. Other than that check for power to ecu and/or error codes.
Have you checked for spark after the engine dies?
whiteytighties is offline   Reply With Quote
Old 10-02-2007, 07:02 PM   #3
rb25drag
rb25drag is making his/her stupidity well-knownrb25drag is making his/her stupidity well-knownrb25drag is making his/her stupidity well-knownrb25drag is making his/her stupidity well-knownrb25drag is making his/her stupidity well-known
Send a message via AIM to rb25drag
First take a spark plug out when it will not start and turn it over and make sure you are getting spark no spark no bang. If you are then put the plug back in and check the fuel line again. You might have a clogged filter that pushes fuel every now and again. If it has junk in it you can let it set for a while and when you come back and it starts is because the garbage has settled at the bottom until you start it again.
If you are getting both fuel and spark there is no reason for it not to start.
Also check your gas cap and make sure it has no pressure on it or it could be vaper locking.
rb25drag is offline   Reply With Quote
Old 10-02-2007, 07:08 PM   #4
OurOnePassion
OurOnePassion's Avatar
OurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really niceOurOnePassion is just really nice
Send a message via AIM to OurOnePassion
Would say check the TPS... but you say it works sometimes and not others?
OurOnePassion is offline   Reply With Quote
Old 10-02-2007, 09:40 PM   #5
steve_o1989
How long does is a fuel filter usually good for? I changed mine not too long ago but it way be over due. I havent checked for spark or anything yet because it is just sitting in a parking lot. Never had this problem until a couple weeks ago and then once that went away, the car ran great until today. It's irritating.
Old 10-02-2007, 10:20 PM   #6
deucen
deucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond reputedeucen has a reputation beyond repute
I was having the same problem with my 240. The car would just crank over and over and not start. What I did was replaced the ignition coil, dist. cap and rotor, wires, plugs and fuel filter. Once those things were replaced, it started up no problem but then my car started to run rich as hell. After doing some research, I found that once the coolant temperature sensor goes bad, the car will run real rich. I replaced that and now the car starts up no problem.
deucen is offline   Reply With Quote
Old 10-03-2007, 04:59 AM   #7
rb25drag
The fuel filter should be changed once evry 6 months or every time you change your air filter/ clean it.
I would say (deucen) is onto something, The way you say it started and then died sounds like its running out of fuel. check for the spark first if its firing then go buy a new fuel filter and try that first. There is a combination going on there.
Old 10-03-2007, 12:31 PM   #8
steve_o1989
Well I get to school this morning and figure I would try to start it up...first try, no problems it fires up. My auto teacher figures that my fuel pump is starting to go on me, I figure its a good time to upgrade to a walbro 255. I am also going to change some of the ignition components while i'm at it. Am I going to run into any problems running a 255 on a completely stock engine? I know I have heard for other vehicles that it will wreck the fuel pressure regulator?
Old 10-03-2007, 04:54 PM   #9
Markovich
Markovich's Avatar
Markovich is an unknown quantity at this point
check you cts if its not plugged in or bad will most likely read -40f and will run pig rich
7-mount sr20det evo3 16g in a 90 240sx coupe
yes its a nisclipse bitch
Markovich is offline   Reply With Quote
