Old 11-02-2002, 10:20 PM   #1
revat619
Retired General
revat619's Avatar
revat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfectionrevat619 is close to perfection
I know there's at least two of you guys on here with H&R springs.(i couldnt remember your names, otherwise i would've used the search). I just wanted to know what shocks you're using with them.and do you have an idea of how long the stock shocks would last with those springs? thanks.
www.Jspec.com
www.SpeedAlliance.com
www.PoweredByMax.net
Instagram: @rjsladerade
revat619 is offline   Reply With Quote
Old 11-02-2002, 10:51 PM   #2
misnomer
misnomer's Avatar
I don't have H&R springs, but. . .
Stock is fine for now, H&R doesn't lower you too much. They are a stiffer spring though, and will result in higher spring rates. You will probably notice the suspension being underdampened (sort of a bouncy and loose feel to it), and your shocks will wear quicker. Really is no way to tell for sure how long they'd last. As always, I'd recommend just saving up for some AGX or Tokico Blues and doing the whole shebang at once, but. . . .
