Old 12-14-2001, 09:44 AM   #1
whateverjames
whateverjames's Avatar
whateverjames has a little shameless behavior in the past
Send a message via AIM to whateverjames
anyone know how to fix the rattle that occurs from 48-54 mph. something about the steering collumn?                                :confused:
whateverjames is offline   Reply With Quote
Old 12-14-2001, 10:23 AM   #2
MingMing
MingMing is an unknown quantity at this point
Send a message via ICQ to MingMing
i need some help too
mine jiggles if i brake...
MingMing is offline   Reply With Quote
Old 12-14-2001, 10:31 AM   #3
HippoSleek
HippoSleek's Avatar
HippoSleek is an unknown quantity at this point
james - sounds like you threw a weight and need to get your tires rebalanced.  That is usually the case when you get a shake at a specific MPH.
Ming - get your front brake rotors resurfaced - they are probably warped.  That causes a shake when braking.
HippoSleek is offline   Reply With Quote
Old 12-14-2001, 11:39 AM   #4
AJ
AJ is an unknown quantity at this point
Send a message via ICQ to AJ Send a message via AIM to AJ
hippo u pimp, solving all the worlds problems <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/smile.gif" border="0" valign="absmiddle" alt=':)'>.. i had the same shack problem, so thanks man, how much should i expect to spend rebalancing them?
AJ is offline   Reply With Quote
Old 12-14-2001, 12:09 PM   #5
HippoSleek
HippoSleek's Avatar
Depends - many shops will do a re-balance for free if you bought/installed the tires there. &nbsp;If not, I don't really know - I'd guess $25? &nbsp;At any rate, it's not too pricey - just call around. &nbsp;You can also get a lifetime balance and rotation from shops for pretty cheap so you don't have to play rotate every few months.
Old 12-14-2001, 12:13 PM   #6
konkman
konkman is an unknown quantity at this point
What speed rating are your tires? &nbsp;I had the same problem with 205/55R16 T rated tires, when I put some H's on my car the vibrations stopped.
konkman is offline   Reply With Quote
Old 12-14-2001, 02:17 PM   #7
HippoSleek
HippoSleek's Avatar
</span><table border="0" align="center" width="95%" cellpadding="3" cellspacing="1"><tr><td>Quote </td></tr><tr><td id="QUOTE">Quote: from konkman on 10:13 am on Dec. 14, 2001
What speed rating are your tires? I had the same problem with 205/55R16 T rated tires, when I put some H's on my car the vibrations stopped.</td></tr></table><span id='postcolor'>
When you put the new tires on, they had to be remounted and balanced. &nbsp;That more likely stopped the vibration.
Old 12-14-2001, 02:46 PM   #8
MingMing
shiz, that sleek hippo be so sexay! haha tks
Old 12-14-2001, 03:02 PM   #9
whateverjames
i'm using h rated 205/60/15 &nbsp;but am switching to Z rated 205/50/15
Old 12-14-2001, 03:36 PM   #10
S14KAT
S14KAT is an unknown quantity at this point
When was the last time your checked your brakes. &nbsp;Nissan rotors are known to warp very easily. &nbsp;You made just need to get your rotors re-surfaced, to get rid of any imperfections. &nbsp;My steering wheels shakes like a mutha, and I'm pretty sure I need a brake job. &nbsp;So I&quot;m gonna get some cross-drilled Brembo rotors front and back, and Axxis metal masters, or some other form of metal or carbon based pads. &nbsp;Hopefully that does the trick....we'll see.
S14KAT is offline   Reply With Quote
Old 12-14-2001, 04:50 PM   #11
MingMing
brake job eh? hhmm i could sure go for the other types of jobs...
the ones for ddown there...
rear lsd installation job ofcourse!
Old 12-14-2001, 07:52 PM   #12
Guest
Posts: n/a
Ming ming ....... u were about to get beat by s14grl lol thats funny tho <img src="http://www.zilvia.net/f/iB_html/non-cgi/emoticons/tounge.gif" border="0" valign="absmiddle" alt=':p'>
