Old 10-12-2007, 01:53 AM   #1
twofortyrida1388
twofortyrida1388's Avatar
twofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura about
Tranny Diagnosis..Help Please
I know my TOB is bad because I can hear it knocking at idle and when I press the clutch in it stops. Another thing it does is at first it only did it in reverse. I would notice lots of noise/vibration from shifter first then when slipping the clutch to get moving there is this very un-settling whirling/grinding (idk) its weird. It used to do it once a week or so and now its daily in 1st, 2nd, and reverse. I've also been grinding a lot of gears lately too. I even go as far as taking a second or 2 between shifts and making absolutley sure the clutch is fully pressed in; 3rd and 5th are the worst. If I put 3rd to 5th at like 3500-4k it grinds every time. Is the tranny trash or what? Thanks in advance
Sterling
Boost Coming soon...
twofortyrida1388 is offline   Reply With Quote
Old 10-12-2007, 02:57 AM   #2
supreme_1
supreme_1 is on the path to ruinsupreme_1 is on the path to ruinsupreme_1 is on the path to ruin
i had a similar post like this, but mines is a whining sound. from what people told me is that if the TOB was bad then it would do it all the time, and get worse when you push in the clutch. i think thats what they said. possibly input shaft bearing?
supreme_1 is offline   Reply With Quote
Old 10-12-2007, 01:38 PM   #3
twofortyrida1388
Trannys are something that I've never messed with. I need someone who knows ka trannys well to drive it.
Old 10-13-2007, 12:25 AM   #4
twofortyrida1388
Sooo...What could be happening here?
Old 10-13-2007, 12:33 AM   #5
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
Try changing your tranny fluid this weekend and see if your still having a problem! Or your synchros might be going bad
rps13drift is offline   Reply With Quote
Old 10-13-2007, 12:52 AM   #6
twofortyrida1388
I was thinking that. I might just try to find another tranny. I mean it has served me well. It got beat on daily for the past year with all of its glorious 260k. I might pay to have that done if I think it will help. I heard it was a major pain in the cock hole to do. Would it be worth putting redline in it?
Old 10-13-2007, 02:06 AM   #7
Turtle
Turtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymoreTurtle is not welcome here anymore
You get can get tranny rebuild kit from autozone with synchros and everything for like 130$ so you don't have to spent like 300$ on another tranny not knowing if its good or not. You can send the transmission with the kit to a transmission rebuild place and you can get it rebuilt for like 1-200 dollars.
Turtle is offline   Reply With Quote
Old 10-13-2007, 03:32 AM   #8
twofortyrida1388
Very true. A lot of my buds have 240's and I might be able to get one for a hundred or so.
