Old 12-13-2001, 08:16 AM   #1
TRM02
TRM02 is an unknown quantity at this point
Send a message via ICQ to TRM02
Hello all well I found someone local that can get me a S14 SR20DET motor.  for $2500, BUT no ECU or wiring.  The guy told me that I could have Jim Wolf Technology to reprogram my ECU to run that motor.  Also won't I need a distubuer since the SR motor run coil pack?  Has anyone done a swap like this. Also would you recommend it to anyone else?
TRM02 is offline   Reply With Quote
Old 12-13-2001, 08:24 AM   #2
uuninja
uuninja is an unknown quantity at this point
Send a message via AIM to uuninja Send a message via Yahoo to uuninja
Yes JWT programs ecu's for the sr, however you will still need to do some ammount of Wiring modification make the motor run. I would call JWT and ask exactly what is needed as far as a harness as you may be able to use a modified KA harness. Also make sure that other critical parts like the Ignitor ship are included.
(Edited by uuninja at 9:47 am on Dec. 13, 2001)
uuninja is offline   Reply With Quote
Old 12-13-2001, 08:44 AM   #3
jay
jay is an unknown quantity at this point
Make sure it has an intake manifold too. I have seen a lot of motor on Ebay and such with no intake manifolds. And make sure it has an ignitor chip as uuninja said. Those things are not cheap and the motor will not run without one.
jay is offline   Reply With Quote
Old 12-13-2001, 08:48 AM   #4
TRM02
Thanks I am wait for Jim Wolf to open so they can pick up there phone...Ok, So I have to find out that the motor comes with a intake manifold and ignitor chip anything else?
Old 12-13-2001, 09:55 AM   #5
uuninja
Water pump, intake and TB, MAF, Ignitor chip are the big ones. Thought if you are getting a JWT ecu you can have them program it for a z32, cobra, or other maf.
If you are in cali 2500 for an incomplete motor is not a bargain. SR's these days are by no means rare. Depending upon how much stuff is missing I might shop around more.
Old 12-13-2001, 10:26 AM   #6
oberkill
oberkill is an unknown quantity at this point
The JWT distributer setup sucks! Dont use it. You will be alot better off getting a complete engine and it will work out cheaper as well.
Alan
oberkill is offline   Reply With Quote
Old 12-13-2001, 11:05 AM   #7
Arcane
Arcane is an unknown quantity at this point
i'd probably listen to oberkill...since he co-owns boostdynamics, which specializes in 240's, plus...even though i never had the privilege of doing business with them, i've heard that they are very knowledgable(sp?) and pretty cool guys...i've talked to louis about doing an sr swap and he was very helpful and you can tell that he knows what would help and what wouldn't....well, whatever you do...good luck...(how's that for a plug)?
Arcane is offline   Reply With Quote
Old 12-13-2001, 12:18 PM   #8
TRM02
uuninja, can you help me out on finding a motor?  I am in chicago,il so I am kind of stuck.  It guess I am going to find a full swap with a ECU
Old 12-13-2001, 02:42 PM   #9
uuninja
Talk to <a href="www.soko.com" target='_blank'>www.soko.com</a> they are local to you and have been in the game for a while. There is also <a href="www.unstable-hybrids.com" target='_blank'>www.unstable-hybrids.com</a> and <a href="www.srswap.com" target='_blank'>www.srswap.com</a> both reputable and well know in the SR community.
