Old 10-16-2007, 02:06 PM   #31
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
Originally Posted by Dream240 View Post
The "camshaft position sensor" is attached to the Dist. housing on the S13/S14. The "crank position sensor" is only used in S14s and is attached to the bellhousing. FYI
He would be throwing an 11 and 21 codes respectively if he was having a problem with the CMPS. If that was the case, then you could assume a problem with either the cam positions themselves or more than likely a faulty sensor.
Do we have ANY codes pulled yet?
well obviously one Crank positioning sensor is automatically removed from the pic
im just throwing things out there that people told me would prevent me from getting spark
Old 10-16-2007, 03:23 PM   #32
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
Well judging from the experience of alot of Zilvians lately, I'm just trying to keep the definitons clear to avoid confusion. And yes the crank sensor would obviously not be a culprit here.
CPS is sometimes referred to as either the "Cam" position sensor, or the "Crank" position sensor.
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 10-16-2007, 03:44 PM   #33
daryl337
daryl337's Avatar
daryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura aboutdaryl337 has a spectacular aura about
Send a message via MSN to daryl337
he needs to tell us.. does he have NO SPARK (as in you can't see crap).. or does he have CRAPPY spark?
BIIIIIIIIIG difference.
This is my clever and witty signature.
daryl337 is offline   Reply With Quote
Old 10-16-2007, 07:34 PM   #34
s13bm
s13bm is making his/her stupidity well-knowns13bm is making his/her stupidity well-knowns13bm is making his/her stupidity well-knowns13bm is making his/her stupidity well-known
i got the code 21 but we replaced so much crap the only thing i can think of next would be a bad wire somewhrer
s13bm is offline   Reply With Quote
Old 10-16-2007, 10:13 PM   #35
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
agreed
im thinking set it to TDC and make sure like really make sure ur ecu is bolted down properly..hell make sure u have the rite ECU
Old 10-16-2007, 10:20 PM   #36
35suren
35suren's Avatar
35suren is making his/her stupidity well-known35suren is making his/her stupidity well-known35suren is making his/her stupidity well-known35suren is making his/her stupidity well-known
Send a message via AIM to 35suren
cap and rotor
relpace the sprakplug
wires
or maybe the injectors are not fireing right
KAZA IS THE NAME YAHURME LOLOLOLOL JK
35suren is offline   Reply With Quote
Old 10-17-2007, 05:37 AM   #37
Dream240
Dream240's Avatar
Originally Posted by 35suren View Post
cap and rotor
wires
You + Car knowledge = fail
What the hell do the injectors have to do with getting spark? Do us all a favor and just stop working on cars altogether.
Oh yeah, and learn how to use "speel cheeck".
Idiot.
Old 10-17-2007, 02:11 PM   #38
s13bm
i check for power and ground to the ingnition and it has everything just dont kno why i still dont have any spark
Old 10-17-2007, 02:42 PM   #39
pr240sx
pr240sx is an unknown quantity at this point
A good way to check the CAM/CRANK position sensor is by removing it for the engine, disconnect plugs and coil wires BUT leave the harness connected. Wi the key on ON position, rotate manually the gear. You should hear the injectors clicking.
If you have power everywhere, even at the coil, I insist, check the ignition module. Its job is to switch power on/off so the coil sparks.
Get a good working one and test. Its simplier than testing the CAM/CRANK sensor and only takes 30 seconds!!!
pr240sx is offline   Reply With Quote
Old 10-17-2007, 03:02 PM   #40
s13bm
the ignition module is bolted on right onto the coil right
Old 10-17-2007, 03:59 PM   #41
Dream240
Dream240's Avatar
No the ignition module is attached to the dist. via the only connector sticking out of the dist. housing.
The part you're thinking of is the ignition power transistor, which is attached to the back of the coil pack and it's mounting bracket.
The other component next to the coil is a simple resistor, which should last you the life of the car.
Old 10-17-2007, 04:26 PM   #42
s13bm
on the plug to the distributer which ones should have power and ground
Old 10-18-2007, 12:01 AM   #43
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Dude, I sent u a WIRING DIAGRAM and testing info on every ignition part I could find and you are still asking wiring questions? Maybe you should just take it to a shop.
Old 10-18-2007, 08:10 AM   #44
Dream240
Dream240's Avatar
This is officially the 1 millionth time I've posted this link.
http://www.240edge.com/manuals/usdm-cars.html
get your FSM and solve your problem.
Old 01-09-2014, 12:13 AM   #45
boneout
boneout is an unknown quantity at this point
So what did it end up being im having a similar problem?
boneout is offline   Reply With Quote
