Old 10-17-2007, 12:21 PM   #1
altalti
altalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura aboutaltalti has a spectacular aura about
s14 rear camber adjustment??
I would llike to know if there is a way for me to adjust the rear camber on my s14 i think i got some negative camber going on. I have d2 coilovers and that is all that is modified on my suspension. nopw for the NOOB question of the day. How do i adjust the camber??
altalti is offline   Reply With Quote
Old 10-17-2007, 12:27 PM   #2
projectRDM
projectRDM's Avatar
With the OE eccentric bolt, just like any other car.
FORMERLY R240NA
Old 10-17-2007, 12:30 PM   #3
altalti
could anyone point me to this bolt is it on the car or do i have to buy it like my queston suggests im completely useless when it comes to suspension.
Old 10-17-2007, 12:41 PM   #4
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
either way if you lowered with coilovers you need some adjustable arms t fix it fix your ride height to the rest of your suspension. as someone famous said "the need must fit the means"
bigOdom1 is offline   Reply With Quote
Old 10-17-2007, 12:44 PM   #5
aznpoopy
aznpoopy's Avatar
location of adjustment bolt:
pull off the rear wheels and jack up the rear wheel
look for the arm in the back that is up on top and loops around the shock
follow it to where it bolts to the car
that bolt allows you to adjust camber by turning it
but it only allows for a small amount of adjustment, and its probably rusted to shit and seized.
but now, for the real answer:
to get it adjusted properly, you need to go to a shop and get a real alignment.
to get it adjusted into spec, you may need to install aftermarket camber arms and then go to shop and get a real alignment, depending on how much you lowered the car.
Old 10-17-2007, 02:01 PM   #6
Okinawandrifter87
Okinawandrifter87's Avatar
Trader Rating: (22)
Okinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfectionOkinawandrifter87 is close to perfection
Feedback Score: 22 reviews
Correctamundo!!!
Driftphreak87
Okinawandrifter87 is offline   Reply With Quote
Old 10-17-2007, 02:32 PM   #7
S14DB
AFC #1
S14DB's Avatar
Old 10-17-2007, 02:38 PM   #8
altalti
thanks a lot now i just need to find some nice camber arms anyone have any suggestions i want it to be decent quality but i really dont have a fortune to spend. links would be a big plus.
Old 10-17-2007, 02:41 PM   #9
Gumballf355
Gumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to beholdGumballf355 is a splendid one to behold
Send a message via AIM to Gumballf355
How low did you drop the car?? Camber is something you shouldn't adjust yourself. Go get yourself a professional alignment.
Gumballf355 is offline   Reply With Quote
Old 10-17-2007, 02:49 PM   #10
bigOdom1
bigOdom1's Avatar
spl parts carries the cusco unit at a fair price. i trust the stuff for sale on that site
Old 10-17-2007, 02:58 PM   #11
altalti
my car is pretty low probably about 3 inches lower then stock and i just need to get whatever i need before i go to alignment shop i have a killer alignment shop 2 miles from my house just want to have all the parts when i go in there.
Old 10-17-2007, 03:02 PM   #12
aznpoopy
aznpoopy's Avatar
at the minimum you should get
rear camber arm and rear toe arm
i also suggest new t/c rods and inner/outer tie rods up front
for budget quality don't get anything with a solid joint.
get the spc rear adjustable arm set
adjustable and uses hard urethane bushings
you can get it on ebay.
they actually just revised their s14 ruca design
if you want one with heims
i suggest peak performance or battleversion
but toe and ruca is going to cost you
Old 10-18-2007, 08:04 AM   #13
altalti
anyone have a link to some or maybe a set for sale. 95 240sx.
Old 10-18-2007, 09:12 AM   #14
projectRDM
projectRDM's Avatar
www.google.com might help you there. Or should we come over with a set and install them for you too?
FORMERLY R240NA
