Old 10-17-2007, 07:36 PM   #1
nicku
nicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enoughnicku will become famous soon enough
s13 cams questions
Hey....
I have peak performance pro version valve springs, and Brain Crower step 2 cams. Other than that, the car is stock. Will the car run too lean or it will add performance?
And if I happen to have only the pro version valve springs, but with the stock cams, will it cause any bad thing to the car?
nicku is offline   Reply With Quote
Old 10-18-2007, 08:03 AM   #2
Sileighty_85
Sileighty_85's Avatar
You'll need to tune the ECU for the cam.
You can run aftermarket Valve spring with Stock cam it will be fine.
Im Running B/C Valve Springs with stock cams with no probs
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 10-18-2007, 09:33 AM   #3
all stock
all stock is on the path to ruinall stock is on the path to ruin
like sileighty said,
increasing the lift or duration of the profile will affect a/f mixture into the chamber, you're going to need to fix your timing and fuel delivery to optimize.
NASA PTD/SCCA ITS
all stock is offline   Reply With Quote
Old 10-18-2007, 11:06 AM   #4
nicku
oh really? Cz i thought it says the BC step 2 264/264 is plug and play, you dont need any extra mod on your car
Old 10-18-2007, 11:52 AM   #5
Sileighty_85
Did you get the street or race Spec Cams?
the Race 264's require stronger Valve springs and B/C Recomends to get a tune for the Race Specs
If you had some 256's you could use stock valve springs and no tune
後輪駆動車1番
1986 SR86 - 200ish
Old 10-18-2007, 11:56 AM   #6
((sr)) kelly
((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute((sr)) kelly has a reputation beyond repute
get a power fc so you can tune the AFR, fuel timing, and ignition timing
((sr)) kelly is offline   Reply With Quote
Old 10-18-2007, 12:40 PM   #7
steve shadows
steve shadows's Avatar
OMFG
did you PLUG the cams into their Sockets?
then thats a typo for marketing
where is the german shepard when you need one
Like Me on FaceBook !
Old 10-18-2007, 02:39 PM   #8
nicku
well....i do have the peak performance pro version valve springs in the head already...but i have heard if i put the 264/264 street step 2 cams from BC, i will be running too lean. is that true?
the cams is the one on heavythrottle. it says Brian Crower Step 2 Street / Strip Spec SR20DET Cam Set, 264 / 264, 12.06 lift
Old 10-18-2007, 03:11 PM   #9
snappy
snappy's Avatar
snappy is an unknown quantity at this point
I had a set of BC stage 2 cams, I checked on their website and even called a tech from the BC hotline and they all said you wouldn't have to touch anything, they said just put em in and go... but i don't like BC cuz the set of cams they gave me snapped... They gave me another set and took em to a race shop to have em install and it happened again, so I just got my money back... I don't touch BC products anymore.
Originally Posted by holemilk00 View Post
Its a 98 LE (leather edition)
snappy is offline   Reply With Quote
Old 10-18-2007, 03:18 PM   #10
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
You COULD run it untuned,
but you know you'll get more power tuned
word
Anto is offline   Reply With Quote
Old 10-18-2007, 03:21 PM   #11
nicku
really???? thats kinda scary!!! anybody has this kind of experience?
Old 10-18-2007, 04:53 PM   #12
whereda40at
whereda40at's Avatar
whereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nicewhereda40at is just really nice
Send a message via AIM to whereda40at
i dont know that was the first time i have heard of that. i hope my stroker kit i got from b/c doesnt fuck up
WORLDS FASTEST T-2 TURBO 240 ON 93 OCTANE!
10.79 @ 124 MPH WITH A 1.48 60'
whereda40at is offline   Reply With Quote
Old 10-18-2007, 05:06 PM   #13
steve shadows
BC is fine.
Typically user error is to blame, even if you think you did it right.
You need to take torque sequence slow and very steady on cheap parts.
Once all the caps are torqued in then its fine.
HKS you can fucking throw them off a bridge.
thats what I run/
Tomei is good too
Old 10-18-2007, 05:17 PM   #14
whereda40at
Originally Posted by steve shadows View Post
BC is fine.
thats what I run/
Tomei is good too
whats wrong with hks's thats what i run and i dont have any problems with them
Old 10-18-2007, 05:27 PM   #15
Kouki
Kouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud ofKouki has much to be proud of
He wasn't saying anything bad about the HKS, and if you actually read what shadows wrote is that he actually uses the HKS cams himself. When he said that you could fucking throw them off a bridge he was refering to their durability, not saying that they suck. If you read his whole post you would be able to figure that out just from the context of what he was saying.
Kouki is offline   Reply With Quote
Old 10-18-2007, 05:29 PM   #16
whereda40at
i read the whole post but it just sounds different from a typing context and verbal context.
cause i have heard other people talk bad about them before and wanted to know why
Old 10-18-2007, 05:45 PM   #17
steve shadows
no I mean they are strong enough to toss off bridges then use again
Old 10-18-2007, 05:51 PM   #18
Skullavera
Skullavera's Avatar
Skullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfectionSkullavera is close to perfection
Send a message via AIM to Skullavera
I believe Steve meant that you can throw them off a bridge and still run them with no problems, i.e. that they are of superb quality. Re-read his post. Why else would he be running them?
Reviews/Feedback!
Skullavera is offline   Reply With Quote
Old 10-18-2007, 05:55 PM   #19
whereda40at
some people could have something and not be happy with it. like my turbo. im not happy with it but i have it.
