Old 10-21-2007, 05:57 PM   #1
guitaraholic
guitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of lightguitaraholic is a glorious beacon of light
Yellow STI injectors DO work
Well, I put the yellow STI side feed injectors in my car, and it started right up and idled "okay" I could tell it was running a little rich, but it wasn't going to stall, I have yet to install the Z32 MAF or the ECU (both I have, doing that tomorrow, it got too dark). Just letting everyone know there is a nice low cost alternative out there. Hell, you can get them remained from autoparts giant for about $190 for a set of four.
Everything I have read tells me they are 550 high impedance. If anyone has any information that does not correspond to this please let me know. My ECU is chipped so I can tune it for the proper injector size.
guitaraholic is offline   Reply With Quote
Old 10-21-2007, 06:01 PM   #2
Z33dori
Z33dori's Avatar
nice find.......that good to hear
Old 10-21-2007, 06:38 PM   #3
Ninjabread
Ninjabread's Avatar
Sweet.
High impedance means you need to wire in a resistor, right? Is that complicated at all?
613DriftWerks.ca
Ninjabread is offline   Reply With Quote
Old 10-21-2007, 06:45 PM   #4
projekt_s13
projekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfectionprojekt_s13 is close to perfection
Send a message via AIM to projekt_s13
Are you talking about a sr or ka? Not that it would matter much but i would still like to know.
projekt_s13 is offline   Reply With Quote
Old 10-21-2007, 06:49 PM   #5
babowc
babowc's Avatar
babowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfectionbabowc is close to perfection
wasnt this known looooonnnnng time ago?
both KA and SR are high imp sidefeed.
which means, its a direct drop-in.
minus the plugs/clips.
babowc is offline   Reply With Quote
Old 10-21-2007, 06:50 PM   #6
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
I know they fit into our rails (KADE & SR) but the connector is slighty different did you have to change them to teh Sti connector?
Old 10-21-2007, 06:50 PM   #7
Ninjabread
Ninjabread's Avatar
so you need the plugs too, and then just 2 wires?
613DriftWerks.ca
Old 10-21-2007, 06:51 PM   #8
guitaraholic
Originally Posted by Ninjabread View Post
Sweet.
Actually its the other way around. If the injectors are LOW impedance and the ECU requires HIGH impedance, then yes you would require to use a resister to change the impendance of the injectors from LOW to HIGH, otherwise you will burn out the injector driver in the ECU (BAD!!!) because it would draw too much current, lower ohms equals higher current draw, like speakers (I believe). However, from what I have heard if the ECU uses low impedance, and you put in high,, you don't need to do anything.
However the ECU uses HIGH imp and the injectors are HIGH imp (from what I've heard). So you don't need to do anything
Old 10-21-2007, 06:53 PM   #9
guitaraholic
Yes I had to change the plugs, that was pretty easy, I made quick disconnect pigtails, so I can change out the Sr20's 370's or the STI's 550's
BTW,, they don't have to be a STI plugs,, Legacy plugs will work too (that's what I used)
Old 10-21-2007, 06:53 PM   #10
babowc
babowc's Avatar
you just need the clips/plugs, whatever you want to call it.
and you splice it with STI clips.
hopefully you got it with the injectors.. if not, more than likely, autoparts store will have em.
there are two wires, and only two wires.
its really self explanatory after the drop-in.
Old 10-21-2007, 06:54 PM   #11
babowc
babowc's Avatar
thats actually a really good idea..
+1 for that,
never thought of that!!
Old 10-21-2007, 07:02 PM   #12
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Here is a picture of the plugs and injectors for the Sti injectors and im almost positive they are high impendence just like our injectors.
Old 10-21-2007, 07:05 PM   #13
guitaraholic
Yeah,, that's pretty much them,, You can go to Autoparts Giant and pick up some remans for $165, or new Pythons for $190. Either way, its DIRT cheap for a nice injector upgrade. Look up part# 842-18132
Old 10-21-2007, 07:06 PM   #14
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Old 10-21-2007, 07:08 PM   #15
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
The hardest part is gonna be finding the connectors for the Sti injectors as im sure there not easy to find separately
Old 10-21-2007, 07:10 PM   #16
guitaraholic
Actually, not too hard to find,, you can use a Subaru Legacy plugs. There are a lot more Legacies then STI's
Old 10-21-2007, 07:11 PM   #17
Ninjabread
Ninjabread's Avatar
So basically, these are brand new 550, drop in (minus wiring) for 190$.
I'm sold.
613DriftWerks.ca
Old 10-21-2007, 07:17 PM   #18
MURPHY
MURPHY's Avatar
MURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfectionMURPHY is close to perfection
Send a message via AIM to MURPHY
send em some random ass injectors for cores too
MURPHY is offline   Reply With Quote
Old 10-21-2007, 07:17 PM   #19
guitaraholic
Yeah,, hell of a cheaper alternative. I've seen them used go for ~$100-$120 (that's what I got mine for), and remanned for $190-$200.
Old 10-21-2007, 07:20 PM   #20
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
For $190 where, is that for a set? I know you can get them from Autozone for $99.99 an injector but $190 for a set is awesome
Old 10-21-2007, 07:22 PM   #21
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Double Post...msglnght
Old 10-21-2007, 07:24 PM   #22
guitaraholic
It's $47/ injector, so that comes out to ~$190,
Go to Autoparts Giant, and look up 2004 Subaru Impreza STI Turbo 2.5 injectors
Old 10-21-2007, 07:34 PM   #23
Rittmeister
Rittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really niceRittmeister is just really nice
I've been told they're 520cc, not 550, by a guy who has done quite a bit of Nissan tuning with them. Anything to that?
E36 M3 - new project
1990 240SR - screamed down the road
Rittmeister is offline   Reply With Quote
Old 10-21-2007, 07:35 PM   #24
ch1873857
ch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the roughch1873857 is a jewel in the rough
Send a message via AIM to ch1873857
hmm just replaced boss' STI injectors with power enterprise 850s. i have to clip his old clips off and use the PE ones. anyone want them?
ch1873857 is offline   Reply With Quote
Old 10-21-2007, 07:41 PM   #25
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
I do to bad you could send them with the turbo you already sent.
Old 10-21-2007, 07:46 PM   #26
guitaraholic
I guess you could up the fuel pressure a few pounds and make them flow 550 without a prob,, I'm guessing running around 49psi instead off 43.6 should get you at 550cc.
Old 10-21-2007, 07:49 PM   #27
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
I was also going to mention that to, I've heard 520cc.
Old 10-21-2007, 08:46 PM   #28
ch1873857
someone knows what they're talking about.. i just like the sti's baller spray pattern
Old 10-23-2007, 06:20 PM   #29
Tenchuu
Tenchuu's Avatar
Tenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfectionTenchuu is close to perfection
anyone know off hand if they will toss into a RB25 also before i go do all the legwork to find it out?
Tenchuu is offline   Reply With Quote
Old 10-23-2007, 06:31 PM   #30
Antihero983
Antihero983's Avatar
if anyone needs any, i work at a dealership and can get them AT cost!
